Roto Zip Bit Experiment - Failure
Postby Mark's Wood Chips » Sat Apr 29, 2017 5:10 pm
In my quest to find an inexpensive down cut spiral bit in my CNC, I tried a 0.125" Roto Zip bit. Things looked promising for about 3 minutes then the bit broke running at 18K @ 60 ipm. OK, so I need to fiddle with speeds and feeds right? Not! Upon inspection, I discovered that the bit flexes a tremendous amount. The photos show a thru hole centered in a hex pocket except for the fact that the hole isn't round (yes, it was drawn as a circle). The profile cutout shot clearly shows significant flex during ramped plunges. Lesson learned and added to my wall of shame. :oops:
Roto Zip Bit
Ramped Plunge Flex
Not Even Close to Being Round
Mark's Wood Chips
Model of CNC Machine: ShopSabre 23 with Rotary
Re: Roto Zip Bit Experiment - Failure
Postby highpockets » Sat Apr 29, 2017 5:52 pm
Nice experiment Mark.
I have trouble not breaking Roto Zip bits by hand. If you look at how they are cut there isn't much center stock.
Postby TReischl » Sat Apr 29, 2017 6:18 pm
Mr Mark, if you are looking for CHEAP .125 bits try eBay. I bought two ten packs, one pack is flat bottomed cutters, the other is ball nose.
You will need a .125 collet if you do not already have one. I tried one of those adapter collets. That did not work real well, seems it did not hold onto the bits very well at all.
The cost was less than $10 for ten of them.
Here is a link:
http://www.ebay.com/itm/10X-1-8-Carbide-Flat-Nose-End-Mill-CNC-Router-Bits-Double-Flute-Spiral-17mm-/400934496161?hash=item5d598ee7a1:g:1OYAAOSwv0tVdU4z
What has surprised me is that I am still on my first one! I have cut quite a bit with it. At a buck a piece it is hard to beat.
Postby ger21 » Sat Apr 29, 2017 6:44 pm
ger21
Postby highpockets » Sat Apr 29, 2017 6:44 pm
I've had really good luck with the cheap ebay bits, they seem to last pretty good. Maybe I'm just not that picky.
The problem is I've yet to find a down spiral cheap bit. I think that is what Mark was going for.
Postby highpockets » Sat Apr 29, 2017 6:46 pm
As I typed.... Thanks Gerry. :D :D
Postby Mark's Wood Chips » Sat Apr 29, 2017 8:49 pm
I use 0.125" spiral end mills and ball nose bits purchased from Ebay vendors and I'm pleased with the cut and longevity. Might have to wait a few weeks for delivery but you can't beat the price. I use ER-16 collets and they work well in my Porter Cable router - adapter and collets purchased from Precise Bits.
Highpockets was right, I'm looking for down spiral bits without breaking the bank.
Mark
Mark's Wood Chips
Postby scottp55 » Sat Apr 29, 2017 10:17 pm
+1 Ger,
I use Drillman1's .125 and .0625" Downcuts all the time in a variety of hardwoods with excellent results, and usually get the bits within days.
Ordered several times, and always fast shipping and consistent high quality and dimensions.
GMH
scottp55
Postby ElevationCreations » Sat Apr 29, 2017 11:37 pm
+1 for Drillman1 on eBay.
ElevationCreations
Model of CNC Machine: Shapeoko SO3 XXL & SO3
Postby armbrusterco » Sun Apr 30, 2017 2:28 am
+2 for Drillman.
Bob Armbruster
www.ArmbrusterCo.com
armbrusterco
Model of CNC Machine: Roland MDX-40A
