What Do I Need For My 5hp 230V Spindle?
Postby dan_barber » Thu Apr 20, 2017 7:06 pm
I used to power it with 230V 3 phase, but I am running out of a residential garage now, so the static controller will not work. I assume I will need another controller.
I am not sure about 230v single and 3 phase, although from what I have read the 230v available in a residence will be single phase.
Will this unit work? http://shop.actechdrives.com/AC-Tech-Lenze-ESV402N02TXB-p/esv402n02txb.htm
dan_barber
Re: What Do I Need For My 5hp 230V Spindle?
Postby potzmannwoodshop » Thu Apr 20, 2017 7:09 pm
YOu need a 5hp Variable Frequency drive. I suggest leaving this job to a pro. Hiring an electrician will pay for itself by making sure you are set up correctly.
potzmannwoodshop
Model of CNC Machine: 2 SCM Routech Record 120s(1999, 2001)
Postby IslaWW » Thu Apr 20, 2017 10:01 pm
Dan...
I would qualify this a bit more. You either need a 5 HP single phase rated VFD or a 10 HP 3 phase unit.
Plus 1 to the hire a qualified tradesman
Gary Campbell
CNC Technology & Training
GCnC411 (at) gmail.com
IslaWW
Postby dan_barber » Thu Apr 20, 2017 11:11 pm
5 HP single phase rated VFD output is equal to a 10 HP 3 phase unit?
dan_barber
Postby ger21 » Thu Apr 20, 2017 11:46 pm
When you run a bigger 3 phase VFD in single phase, you need to derate it 50%
ger21
Postby garylmast » Fri Apr 21, 2017 12:39 pm
Before you go to a lot of expense in hiring a electrician or other conversion, you may consider a 3-phase to single phase converter. Although I purchased one going the other way (single to three-phase), they are fairly cheap, usually under $200. Do a Google search and you should find something. The 5-hp spindle don't require a lot of ampage, so consider that before you buy. Gary
garylmast
Postby ger21 » Sat Apr 22, 2017 12:26 pm
ger21
Postby AlbertaClipper » Sat Apr 22, 2017 8:36 pm
You need to send it to me and I'll send you my Colt :wink:
AlbertaClipper
Model of CNC Machine: Home Built
