excitech shm-0609 cnc router
Postby frank taylor » Fri Jan 27, 2017 7:28 am
hi guys just updated to new cnc router problem x axes going in y axes direction and vise versa for y axes any way to get it back to normal???
frank taylor
Model of CNC Machine: bravoprodigy be3030
Re: excitech shm-0609 cnc router
Postby martin54 » Sat Jan 28, 2017 3:24 am
You should be able to just switch the leads over :lol: :lol:
what control software are you running ??
Postby frank taylor » Sat Jan 28, 2017 7:30 am
hi martin
control system nk105g2 hand controller nc studio
frank taylor
Postby martin54 » Sat Jan 28, 2017 10:35 am
OK I'm not familiar with NC Studio but you may need to alter one of the settings in there.
Like I said you should be able to just switch the leads over at the control box end, once you have done that you may find one or both of your axis are now running the wrong way ( negative movement where it should be positive). There should be a way to change the direction in NC Studio set up. I would guess that the hardware (screws/belts & motors ) for the x & y axis are the same so no need to alter the axis calibration but you should check it anyway :lol: :lol:
