Lead screw choice dilemma
Postby cwolfs69 » Fri Dec 02, 2016 1:17 pm
i am replacing the lead screws on my small cnc router. the old screws are 10mm-2mm, 2 lead acme screws, (0.160"/ rev±) and work okay. i am replacing with 1/2-10 acme screws and was debating whether to use single start (0.100"/rev) or 2 start (0.200"/rev) threads. my first thought was single so the it would require less torque to move the axis around the table. but then i thought the stepper motor would have to rotate twice as fast and that can cause problems as well. of course the 2 start would have the closest pitch to the original. does anyone have any thoughts about my choices.
i am also upgrading the stepper motors to higher torque as well, going to 296oz/in vs whatever those that came on my chinese router are, very weak
any thoughts or advice would be helpful. i have been unable to find whether its better with fast travel or less torque when installing lead screws on a cnc.
cwolfs69
Model of CNC Machine: cnc3040 router
Re: LEAD SCREW CHOICE DELEMA
Postby calgrdnr » Fri Dec 02, 2016 3:58 pm
when I built my Joes2006 in 2007 I used 1/2- 2 start went to a 1/2- 5 start what a difference faster and smoother .
CNCzone.com would be the place I would look for answers to your question :)
http://www.cnczone.com/forums/woodworking-machines/?s=b6886eb2aeb807d3f95c92e90ab9a756
calgrdnr
Model of CNC Machine: ShopBot prt with 4g upgrade
Re: Lead screw choice dilemma
Postby Mogal » Fri Dec 02, 2016 7:04 pm
Hello,
Thought I'd chime in as I have the 1/2-10 dual start acme threads on my machine.
For a quick reference, I get a max of 160ipm on my machine which makes for a resolution of nearly 0.0002"
Problem with my machine though, is that I have a bad choice of steppers with a high impedance of 6.8mH (36v)
This makes the motors fairly slow (max of about 285rpm)
With better motors, maybe 300ipm would be doable. (500rpm steppers)
My machine is about 24"x30" and even at my 160ipm isn't too bad for this size of machine.
Chris
Mogal
Model of CNC Machine: DIY CNC
Postby ger21 » Sat Dec 03, 2016 3:06 am
160ipm with a 1/2-10 2 start screw is 800rpm, not 285rpm.
At 285rpm, even a 5 start screw would only give you 142ipm.
ger21
