Router Speed
Router Speed
Postby JMan » Mon Nov 30, 2015 6:26 am
I have the piranha FX and am using a Bosch Colt 1hp. What speed level should i be set at for wood carving? And Litho will be at a slower speed as well?
JMan
Model of CNC Machine: Piranha FX
Re: Router Speed
Postby FixitMike » Mon Nov 30, 2015 7:49 am
When I calculate a speed for wood, it almost always is less than the minimum speed of the Colt. So just set it for the minimum speed.
Ideally, the bit won't get hot, and you will get chips instead of powder. but for me, that means around 5000 rpm at 100 ipm for a two flute cutter.
FixitMike
Re: Router Speed
Postby Ms Wolffie » Sat Dec 05, 2015 1:27 am
Sounds like the US intended Colt is speed selectable, the Australia intended is fixed speed at 12000 rpm.
Very inconvenient.
Cheers
Wolffie
Whatshammacallit
Ms Wolffie
