12 posts • Page 1 of 1<Previous topic | Next topic>
JamesB wrote:It would not be practical to try and write a guide because, as Adrian points out, in most cases it subjective as to what would be "correct". One idea to understand this better would add some standard sized bits to your tool database - 60, 90, 120 (degrees) and then use the toolpath preview to see what different parts (tutorial files?) look like cut with the different bits.
Some of these posts may be of interest too:
viewtopic.php?f=3&t=2164
viewtopic.php?f=2&t=22695&p=161928&hilit=vbit+angle#p161928
viewtopic.php?f=2&t=22657&p=161635&hilit=vbit+angle#p161635
viewtopic.php?f=27&t=21194&p=150188&hilit=vbit+angle#p150188
viewtopic.php?f=2&t=22108&p=157316&hilit=vbit+angle#p157316
The above list was just some of the ones that came up with a search on the forum.
James
IslaWW wrote:These illustrations show the relationship between the various Vbit angles at a given line width. The first showing approximate cut depths for 30, 60, 90 and 120 degree bits when the distance between the lines is around 0.125" or 3mm. The second shows approximate depths on various bits for vectors of various widths from 1/8" (3mm) to 1/2" (12.7mm)
