Dust collector separator
Postby woody53 » Sun Jul 05, 2015 9:28 pm
The attachment 20150705_141909.jpg is no longer available
I have a cheaper Harbor Freight dust collector. It is pretty new, and works great. I ran a pine table top for a beer sign, and had to pause everything to get bigger chunks out of the inlet screen. Other than that works good, but that was a real nuisance stopping . I was doing a roughing 3D with 1/2 inch end mill , 1/4 deep @ 130 IMP. Today made a separator barrel, for $ 65 . Doesnt look very good but ran the same toolpath on the same wood, not a piece of wood on the inlet screen afterwards. Still pics up 99% of dust .
Was worth the morning to make.
woody53
Model of CNC Machine: Probotix Meteor 25 x 50
Re: Dust collector separator
Postby ger21 » Sun Jul 05, 2015 11:35 pm
The first thing that most people do is remove the screen. :)
ger21
Postby scottp55 » Mon Jul 06, 2015 12:57 am
If you rough against the grain, it pretty much eliminates the big chunks/splinters I've found.
Only 2.5" inlet on my dustfoot, so it used to be Very annoying, and easily clogged until someone tipped me off.
GMH
Postby Mike-S » Wed Jul 15, 2015 3:39 pm
If you can get another lid, I'd suggest repositioning the holes. The one from the CNC should be on the edge (I'm assuming you have a 90 deg elbow inside the can and a baffle.) The output to the vac should be in the center of the lid (center of vortex) so you only suck up fine dust, not chunks. The chunks should be flung to the can's circumference and fall to the bottom.
I have a similar set up and only get a hand-full of dust for each foot of chips in the can.
Mike-S
Postby Bobtail Farm » Sun Jul 19, 2015 7:51 am
Attached is what i built for a similar Harbor Freight dust collector (based on the designs/builds I saw on the internet). I too observe only a small amount of dust in the bag for a lot of waste in the can. My "inlet" is into the side of the can and located between the top of the can and the thein baffle (the plywood I've attached to the top using threaded rod).
Hope the photos help you.
Bobtail Farm
