Need Help and Advise of what is Happening to my work
Postby Jane Ndungu » Mon Mar 30, 2015 9:09 pm
Hi there,
kindly requesting for some advise if may be anything is wrong with my timber since am having this problem quite often
Jane Ndungu
Model of CNC Machine: TS1325
Re: Need Help and Advise of what is Happening to my work
Postby Jane Ndungu » Mon Mar 30, 2015 9:11 pm
Jane Ndungu wrote:
Hi there,
This are standard doors with a thickness of 1inch panel
Regards
Jane.
Jane Ndungu
Postby Rcnewcomb » Mon Mar 30, 2015 11:57 pm
What is the moisture content of the wood when you cut it?
Postby alan254 » Tue Mar 31, 2015 11:50 am
wood needs to be dried a lot more. Are you using native wood? How are you storing wood prior to use?
Al
alan254
Model of CNC Machine: mechmate, vcarve pro 7.5
Postby Rcnewcomb » Tue Mar 31, 2015 5:45 pm
Warping, splitting, and shrinking are usually due to moisture content. Dale had some good insights to how he handles moisture content issues in this thread: ->Link
Postby ChrisInEstes » Tue Mar 31, 2015 6:00 pm
It's hard for me to be sure from the pictures, but, it looks like you're not leaving enough thickness. That, with the possibility of not-dry-enough wood, could be the problem.
Chris
ChrisInEstes
Postby Jane Ndungu » Wed Apr 01, 2015 11:14 am
Thank You all for the kind response. the timber moisture is between 12.5 and 19.7. This might be part of the problem and also the thickness of the timber. I am going to change all this and see the difference. thanks for the hints.
Regards
Jane.
Jane Ndungu
Postby Adrian » Wed Apr 01, 2015 12:26 pm
That's almost certainly it. Back when I did cabinet making for boats I wouldn't start machining until the wood was down to 10%.
Postby larrybadgett » Wed Apr 01, 2015 4:59 pm
I process all my own wood from the tree to the finished product and always take the rough lumber down to between 6 - 8 % moisture, leaning toward 6.
Woodchip
Wud Bi Tek
http://wudbitek.com/
larrybadgett
Model of CNC Machine: ShopSabre
Postby esteeme1 » Wed Apr 01, 2015 8:13 pm
Jim Darlas
"Can Do!"
http://www.esteemedwoodcrafts.com/
http://www.esteemedplaques.com/
esteeme1
Model of CNC Machine: Cobra 404 ATC; ROMAX WD-1; Shark
