Touch plate on the Piranha
Postby mickey222 » Mon Dec 22, 2014 4:21 pm
Where does the touch plate connect to the Piranha ? It looks like it could be the controller or the display. Thanks for any help.
mickey222
Model of CNC Machine: Piranha
Re: Touch plate on the Piranha
Postby nicksilva » Mon Dec 22, 2014 4:39 pm
Right here:
"Out of my mind. Back in 5 Minutes."
nicksilva
Model of CNC Machine: ULS M300, Rockler 60th Ann. Shark
Postby mickey222 » Mon Dec 22, 2014 7:13 pm
Thank you.
What is the jack on the side of the controller for, do you know??
mickey222
Postby mickey222 » Mon Dec 22, 2014 7:14 pm
Sorry, I meant on the side of the display panel
mickey222
Postby nicksilva » Tue Dec 23, 2014 4:04 pm
sorry don't know. But if you post this same questions over at the shark forum,
Tim Owens from nextwaveautomation will often chime in.
nicksilva
Postby mickey222 » Thu Jan 01, 2015 10:22 pm
The touch plate does not work plugged into the controller, it needs to plug into the small display. The system does not see the touch plate plugged into the controller but works just fine when plugged into the small display unit.
mickey222
Postby nicksilva » Fri Jan 02, 2015 1:09 am
well then that means the plug in the controller will be for the digital probe.
nicksilva
Postby creativescrollworks » Sat Apr 28, 2018 6:58 pm
Where is the touch plate placed on the material?
creativescrollworks
Model of CNC Machine: Piranha LX
Postby Adrian » Sat Apr 28, 2018 7:33 pm
Depends where you want the z zero to be. If you have z zero set to Material Surface then a touch plate is placed on top of the material. If it's set to Table Surface then it's placed on top of the spoilboard.
Postby creativescrollworks » Sat Apr 28, 2018 7:42 pm
Is it placed at the XY datum?
creativescrollworks
