Is this a sign of bearing failure?
Postby SIBUD » Tue Jul 22, 2014 11:32 pm
Here are some photos.
The first are of a carving I did a few weeks ago.
The letters and design cut pretty well with clean smooth edges.
The next ones are ones I did today.
They are rough and fuzzy.
I'm wondering if this is an indication of bearing failure.
Brand new blade in the bit today. Everything else is the same.
Thanks in advance for help as I need to finish this for an anniversary gift for my son and daughter-in-law.
Bud Meade
Nashville, IL
I don't own too many BMW motorcycles, I just have too little time.
SIBUD
Model of CNC Machine: Signal Seeker 24X24
Re: Is this a sign of bearing failure?
Postby Leo » Wed Jul 23, 2014 2:38 am
The woods look different to me.
Wood can DEFINITELY make that much of a difference.
What are the wood species that are shown in the 2 pictures?
Soft woods do not cut as nicely as hardwoods.
www.leosworkshop.com
Leo
Postby SIBUD » Wed Jul 23, 2014 3:09 am
They are both cherry. The first one is stained and oiled.
The second is unfinished.
Bud Meade
Nashville, IL
SIBUD
Postby scottp55 » Wed Jul 23, 2014 11:54 am
You said "New blade in the bit" What bit? and are you Positive it's sharp/aligned/seated tight? Any more vibration than normal? Any way you can check the angle?
scottp55
Postby WoodEraser » Wed Jul 23, 2014 12:50 pm
What router are you using and how many hours do you have on it ?
Eric
The WoodEraser
Liberty Twp (N. of Cincinnati & S. of Dayton) Ohio
WoodEraser
Model of CNC Machine: Shark Pro Plus
Postby SIBUD » Wed Jul 23, 2014 1:28 pm
It is an Amana bit with replaceable blades. http://www.toolstoday.com/p-5671-cnc-v- ... nives.aspx
The router has about 150 hours of run time. Bosch 1617EVS 2-1/4 HP Variable-Speed Router
Bud Meade
Nashville, IL
SIBUD
Postby gordread » Wed Jul 23, 2014 2:38 pm
Did you do anything to the wood before you carved it? If you put finish on first, then you will get slightly more crisp edges, and I've found a slightly cleaner cut.
I've also noticed a difference in the quality of cut between boards of the same species of tree. Sometime it is just a different grain pattern, or a softer piece of wood.
I've found with v-carving that sometimes it is a good idea to run the pattern twice, that way if the result of the first time is 'fuzzy' then the second time through will clean it all up.
I know that this doesn't definitively give you an answer, but hopefully there is something useful here.
Gordon
gordread
Model of CNC Machine: CNC Professor HDX
Postby Mobius » Wed Jul 23, 2014 2:52 pm
It could be a difference in the moisture content of the wood as well, with the fibres of the 'wet' wood bending rather than cutting cleanly. Like gordon said, try cutting it again to clean it up.
Connor Bredin
www.distinctive-concepts.ca
Mobius
Postby Leo » Wed Jul 23, 2014 5:23 pm
Cherry cuts better than your second pic.
I suspect the cutter at this point.
Do you have a non insert type "V" groove cutter to try and compare.
Leo
Postby SIBUD » Wed Jul 23, 2014 9:45 pm
But the first example was cut with an insert bit.
Why would I not expect the same results?
No one has yet addressed the possibility of bearing failure. Still wondering if that is the cause????????
Bud Meade
Nashville, IL
SIBUD
Postby Leo » Wed Jul 23, 2014 9:57 pm
SIBUD wrote:But the first example was cut with an insert bit.
Because it is the one thing that you changed.
If everything else has not changed and you changed one thing - that would be the most suspect.
In systematic troubleshooting - you want to eliminate the easiest things first.
So - by cutting the same program in the same wood - but with a "known" good cutter - you will possibly eliminate the bearing and also the insert cutter as suspects, OR - prove beyond any shadow of doubt that there is still a problem - depending on the results. Doing the test will provide information that you do not have now.
Going after the bearing is not the easy stuff - and that may not be the problem.
Bearings just don't fail suddenly - and the way you explained this is that is was a sudden failure.
Leo
Postby SIBUD » Thu Jul 24, 2014 10:58 am
Thanks Leo. :D
Bud Meade
Nashville, IL
SIBUD
Postby Woodbutcher-59 » Thu Jul 24, 2014 3:13 pm
Hi all,
gonna throw in my 2 cents...
I've worn out bearings in a PC 690 router and also used up a 2.2kw water cooled spindle from China....
Both times the first symptom was more and more noise during spin down after shutting off the motor.
The router motor eventually developed ALOT of radial play in the shaft....
The 2.2 spindle motor developed quite a bit of axial play but no radial play at all...go figure.
I've since learned these Chinese spindle bearings are not so good for straight plunging cuts so use those ramps wherever possible.
Good luck with your issue, but I'm guessing cutter problem.
Jeff
Aspire 8
Mach 3
" I'm tryin to think but nothin happens " - Curly Howard
Woodbutcher-59
Model of CNC Machine: Homebuilt 3'x5'x6"
Postby Leo » Thu Jul 24, 2014 5:14 pm
Routers in general - are NOT - designed for drilling and plunging.
They DO allow in design for SOME level of plunge cutting - but the design intent of a router is peripheral cutting.
I have sat with CR Onsrud technical people face to face - and talked about their machines as I had a twin 25 hp spindle - twin table machine of theirs before.
That is what they said about plunge cutting.
Leo
Postby Adrian » Thu Jul 24, 2014 6:44 pm
I always ramp and never plunge for exactly those reasons and my spindle has been going strong in a production environment since 2009.
Not sure if it's strictly necessary but I took the view that doing it wouldn't cause any problems and not might do.
Next
