Advice on Water Cooled Spindles
Postby LonePine » Tue Jun 10, 2014 1:39 pm
I have a water cooled spindle on my CNC machine. Its relatively new. The manual for the spindle was 1 sheet of paper. It was written in chinese.
    Do I need to worry about rust?
    How do I keep algae from growing in the water?
    If I am not going to use the Spindle for 8 Weeks should I drain?
    Is there an additive that I need to put in the water?
Whats the deal?
LonePine
Model of CNC Machine: Laguna Tools IQ pro
Re: Advice on Water Cooled Spindles
Postby Woodbutcher-59 » Tue Jun 10, 2014 2:05 pm
Hi Lonepine,
Not to worry, its no big deal...
My cooling system is a 5 gal bucket with a submersible pump and lid to keep out trash.
I used distilled water with some food coloring so I can see it in the clear hoses....
No issues with rust or anything after 3 years, never changed or drained anything.
I have heard a touch of bleach in the water will stop anything from growing but I have not found it necessary.
Hope this helps....
Jeff
Aspire 8
Mach 3
" I'm tryin to think but nothin happens " - Curly Howard
Woodbutcher-59
Model of CNC Machine: Homebuilt 3'x5'x6"
Postby signmarketingman » Wed Jun 11, 2014 6:01 am
you can purchase some radiator water for water cooled computers on amazon.
http://www.amazon.com/PrimoChill-Intens ... ling+Fluid
http://www.amazon.com/PrimoChill-ICE-Wa ... er+cooling
signmarketingman
Model of CNC Machine: Professional done home built.
Postby martin54 » Wed Jun 11, 2014 5:28 pm
My set up is similar to one already described, 25 ltr barrel which contains a submersible pond pump, I have however added anti freeze to the water which will do all the things you mention & you can see when the pump is working. Gets quite cold in Scotland during winter so will also stop the cooling system freezing.
If your buying a pump make sure you buy one with a suitable head, my barrel/container sits under the machine so the water needs to be pumped up hill :D
Postby Leo » Wed Jun 11, 2014 10:35 pm
I was thinking regular auto type antfreeze - but I don't have any experience with water cooled spindles. Wish I did.
www.leosworkshop.com
Leo
Postby martin54 » Thu Jun 12, 2014 2:47 pm
That's what I use in my machine Leo, not had it for that long but has been ok so far. It was a post on another forum that I read about it.
