Some CUTS don't look perfect..
Postby Stompa » Mon Apr 28, 2014 8:14 am
Hi
I have a question about my cuts. Please see the below picture and you will see the very small (close up makes them look bad) lines that are left in the timber.. Its like a very fine furry line.
The thing I'm wondering is... Is this a normal thing??? as I've tried lots of different types of cutters and most times get the same thing. Do you think its that my machine may be out of balance??..
Any help would be very gratefully taken as I'm getting a little frustrated..
Stompa
Model of CNC Machine: Ross CNC 60/12
Re: Some CUTS don't look perfect..
Postby Stompa » Mon Apr 28, 2014 8:18 am
Opps ..... forgot to say that i only seem to get these lines on one side of the cut..
Stompa
Postby Adrian » Mon Apr 28, 2014 8:34 am
Most likely free play in the axes somewhere or the router/spindle is way out of plumb. You shouldn't be able to see any trace at all where each pass starts and finishes if everything is working correctly.
Postby Stompa » Mon Apr 28, 2014 8:43 am
Thanks for that Adrian.. Yes i thought it was to do with the machine.
Ill go email the maker of my machine right now as its only a month old and been doing it from the start..
Stompa
Postby Joey Jarrard » Sun May 18, 2014 9:01 am
How did this turn out for you?
Joey Jarrard
Model of CNC Machine: CAMaster Stinger I & Cobra ATC
Postby Stompa » Fri May 23, 2014 2:06 am
Hi Joey
It was the spindle slightly out of square.. Just used a small square and did a couple of adjustments & fixed the problem..
Stompa
