I Want To Build One
PaulRowntree
Re: I Want To Build One
Post by PaulRowntree »
Rik, this doesn't sound right, at least for my machine with a grounded tool.
Are you using the Figure 8 diagram on page 9 of the C10 manual? Is your tool bit electrically isolated from ground?
Paul Rowntree
vgraves
Model of CNC Machine: CNC Router Parts PRO4848 w/LinuxCNC
Post by vgraves »
Rik,
I think the standard touch plate (and the way I did mine) has only 1 wire soldered to it, and the alligator clip is connected to the second wire. A voltage (+5V) is placed across them from your control board, and when the tool touches the plate, it shorts, and this is interpreted as an input signal by your control system.
Van
angelkarla
Model of CNC Machine: home made
Post by angelkarla »
The resistor I am to use for my board is to be between 220-270 Ohms
Hope this may help you
If all else fails read the instructions
Rik
Post by Rik »
I am doing this to cover all my bases that's all. It remains to be seen as to which scenario it will be.
dougwoodshop
Model of CNC Machine: Multi Cam
Re: How to set up a job server for use with VCarve Pro
Post by dougwoodshop »
Can anyone tell me how to set up and install a job server program for use with Multicam using VCarve Pro 7.5 software?
Doug
Rik
Post by Rik »
Guys, this thread for me is all messed up. Recently, like in December I turned :cry: my control box to smoke so all my stuff is junk and I must start all over with new and cheaper components. Living on fixed income so not a lot of cash at hand. I'll be back though with more crazy issues. So it's back to the drawing board for me. Thanks to all for the comments. :oops:
