Materials to use
Materials to use
Postby Roy Esslinger » Sat Apr 12, 2014 11:18 pm
I would like to know where to find some kind of material to make signs. I saw some one time that was .75 thick and painted red on the outside and when you carved into it the inner core was white. it was very heavy like MDF I think it was about 300.00 per sheet for a 4x8 sheet but I don't remember where I saw it. Hope you guys can direct me. Roy
Roy Esslinger
Model of CNC Machine: home built
Re: Materials to use
Postby Charlie_l » Sun Apr 13, 2014 1:51 am
I think you are referring to King ColorCore plastic which is a high-density polyethylene laminate. Has outer layers of about 0.050 thick color on both sides, then also an interior color. Cuts easy and not much finish required. Cut the first side from the large sheet, then cut lettering on individual signs for second side. Just ordered a couple more 4 by 8 sheets at 200+ each.
Aspire, CAMaster Stinger II
Charlie_l
Model of CNC Machine: CAMaster Stinger II
Postby Leo » Sun Apr 13, 2014 1:01 pm
Roy,
There is a VAST array of materials and supplies out there.
The best way is for you to goggle search the stuff you are looking for.
Try searching on "sign supplies" or "Laminated plastic sheets" ---- "romark" (is a brand name for laminated plastics).
"sign materials"
You "might" be able to find supplies in www.McMaster.com
As you start to see some of the stuff that suits your fancy - remember the terminology - then refine your searches on the terminology.
THEN - look for local sources.
www.leosworkshop.com
Leo
Postby martin54 » Sun Apr 13, 2014 4:37 pm
Register with a signmaking forum & ask on there. Might well be that the material you are looking for is not the best option for your project. If that's the case then they can point you in the right direction as far as materials & suppliers go.
Postby GeneMpls » Sun Apr 13, 2014 5:25 pm
I believe it is Rowmark Leo.
GeneMpls
Model of CNC Machine: PRS Buddy48alpha ,3x4' 130w laser, Wazer
Postby Roy Esslinger » Sun Apr 13, 2014 6:07 pm
thanks for all the info
Roy Esslinger
Postby martin54 » Sun Apr 13, 2014 6:25 pm
Dont know about your side of the pond but over here all Rowmark distribute are engraving supplies & none of their boards would be as thick as asked for.
Try uksignboards.com if you want a friendly sign forum, in the uk but have members all round the world. Try a search for aluminium composite (acm) they have an aluminium skin & foam plastic core, come in a range of colours. The core always use to be black but some manufacturers are now using different colour cores.
