Probotix V90 and Photvcarve
Postby robbie9gallagan » Sun Jan 05, 2014 10:59 pm
I just purchased a V90 by probitix to cut lithophanes on with photovcarve..
Does anyone have the correct feed and speed rates to cut them??? I keep loosing Z height when I cut them... I slowed X and Y and Z down... But having trouble with Z...
X and Y seem to be fine..
robbie9gallagan
Model of CNC Machine: Anderson Stratos Pro
Re: Probotix V90 and Photvcarve
Postby ozymax » Mon Jan 06, 2014 12:38 am
I have read about a similar problem to this on another forum, where the Z was loosing or gaining height and the fix was to run the stepper drives in at least 1/8 micro stepping.
Try that.
ozymax
Postby martin54 » Mon Jan 06, 2014 8:50 pm
What control software are you using? Are you only losing steps when cutting lithophanes or does it happen with other machining as well.
Postby robbie9gallagan » Tue Jan 07, 2014 4:15 pm
usb controller by planet cnc..
only on lithophanes..
robbie9gallagan
