Control box mounting
Postby boxerstoo » Fri Oct 25, 2013 11:44 pm
I am brand new to this and am setting up my machine in my shop and am trying to locate the control box.
Being as there is a fan inside, will it hurt if I mount the box on its side instead on on its rubber feet?
boxerstoo
Model of CNC Machine: Black Diamoond
Re: Control box mounting
Postby PaulRowntree » Sat Oct 26, 2013 3:25 am
Any fan worth using will be able to run in any orientation, just make sure that the air flow is good and it is filtered or out of dust/chip's way. Are there any other components that cause concerns (DVD drive ...) ?
Paul Rowntree
PaulRowntree
Postby boxerstoo » Sat Oct 26, 2013 5:21 am
PaulRowntree wrote:Any fan worth using will be able to run in any orientation, just make sure that the air flow is good and it is filtered or out of dust/chip's way. Are there any other components that cause concerns (DVD drive ...) ?
I assumed as much, thank you for your time
boxerstoo
