Spindle ?
- Ms Wolffie
Spindle ?
When I eventually manage to get my spindle and inverter fitted, how do I determine the speed of the spindle?
I have a speed control knob on the inverter but how can I work out what is whatT?
I am not an electronics genius
Cheers
Wolffie
Cheers
Wolffie
Cheers
Wolffie
Whatshammacallit
Wolffie
Whatshammacallit
- fretsman68
Re: Spindle ?
While there may be cheaper ones found, this is a very handy tool for what I "think" you're after:
http://www.ebay.com/itm/Neiko-Non-Conta ... 51a6ad92e1
Hope that helps,
Dave
Hope that helps,
Dave
Dave
Dave
Re: Spindle ?
Is there a display on the front of the inverter? If there isn't a setting to directly display RPM's it should display the frequency and you should be able to calculate the RPM from there.
- Ms Wolffie
Re: Spindle ?
Unfortunately, they will not ship to Australiafretsman68 wrote:While there may be cheaper ones found, this is a very handy tool for what I "think" you're after:
Hope that helps,
Dave
Cheers
Wolffie
Cheers
Wolffie
Whatshammacallit
Wolffie
Whatshammacallit
- Ms Wolffie
Re: Spindle ?
That means calculations and brain strain, YUKAdrian wrote:Is there a display on the front of the inverter? If there isn't a setting to directly display RPM's it should display the frequency and you should be able to calculate the RPM from there.
Actually, I don't know how it works, I have to learn to read Chinese first
Cheers
Wolffie
Cheers
Wolffie
Whatshammacallit
Wolffie
Whatshammacallit
- fretsman68
Re: Spindle ?
It's not the only one in the world, my friendWolffie wrote:Unfortunately, they will not ship to Australiafretsman68 wrote:While there may be cheaper ones found, this is a very handy tool for what I "think" you're after:
Hope that helps,
Dave
Cheers
Wolffie
Dave
Dave
Dave
- glenn
- Model of CNC Machine: home brew 40x20
Re: Spindle ?
Wolffie,
If yours looks anything like this, it will display the rpm's.
Glenn
Glenn
- Ms Wolffie
Re: Spindle ?
I found a similar one in China that has no problem with shipping here, free delivery even, but neither Amazon nor any other one I found in the US will ship these to Australia.
I do not understand why?????
Cheers
Wolffie
Cheers
Wolffie
Cheers
Wolffie
Whatshammacallit
Wolffie
Whatshammacallit
- Ms Wolffie
Re: Spindle ?
Glenn
It looks like this, very similar.
http://cgi.ebay.com.au/ws/eBayISAPI.dll ... 0977063339
Cheers
Wolffie
Cheers
Wolffie
Cheers
Wolffie
Whatshammacallit
Wolffie
Whatshammacallit
- fretsman68
Re: Spindle ?
Yes, I believe that display will show the RPMs if I'm not mistaken.
Dave
Dave
Dave
Dave
- Ms Wolffie
Re: Spindle ?
If only I could get the thing to work
I connect power to the unit, it says "hello" continues to 00000 the something flashes on and it trips the circuitbreaker.
I have no idea what I have done wrong except that I cannot find the earth connection screw, so I bridged it to the spindle earth.
Cheers
Wolffie
Cheers
Wolffie
Cheers
Wolffie
Whatshammacallit
Wolffie
Whatshammacallit
- rscrawford
- Model of CNC Machine: CAMaster Cobra 408 ATC, ShopSabre IS408
Re: Spindle ?
Spindles require a lot of power, I'm assuming a 2hp is 220v, 20A. Maybe the breaker is tripping because it is trying to draw more current on startup than your breaker allows.
Russell Crawford
- Ms Wolffie
Re: Spindle ?
No, the spindle is 220V, 8 amp.rscrawford wrote:Spindles require a lot of power, I'm assuming a 2hp is 220v, 20A. Maybe the breaker is tripping because it is trying to draw more current on startup than your breaker allows.
The inverter even trips the breaker without the spindle connected.
The seller has just confirmed that there is no earth connecting screw in this model.
Where on earth/how do I connect the earth wire?
Cheers
Wolffie
Cheers
Wolffie
Whatshammacallit
Wolffie
Whatshammacallit
- Model of CNC Machine: home built 3 soon 4 axis
Re: Spindle ?
Pin 9 the one with the big E should be your earth. I have a attached a picture of mine with connection details as supplied. Remember that RST is the live in and UVW are the spindle connections.
Bruce
Bruce
- Ms Wolffie
Re: Spindle ?
I wish mine looked like that but it doesn't
WolffieCheers
Wolffie
Whatshammacallit
Wolffie
Whatshammacallit
