A simple way to make inlays
Re: A simple way to make inlays
Postby scottp55 » Wed Mar 23, 2016 2:00 pm
Also maybe to speed up testing, try using medium CA only on the female(do the edges and usually enough flows down to do the flat).
Make sure you dry fit and draw pencil marks on corners, plus one for reference, as open time is like 15 seconds.
Leave clamped with the Male side down so any glue goes on waste.
Usually 1 hour clamped does it, and had no failures on the ones I did 2 years ago, even though they've been dropped and banged around a little with major temp changes.
GMH
scottp55
Postby Paul Z » Wed Mar 23, 2016 2:34 pm
Greg,
If you still have gaps on your latest try, you might want to use a trammel to be sure your cutter is perpendicular to the bed.
Paul Z
Paul Z
Model of CNC Machine: shopbot PRT Alpha 96x48
Postby Greg J » Thu Mar 24, 2016 3:48 am
Thanks for the reply's guys!!
Just got home from the day job and ran out to the shop. Using a dial indicator and the trammel method .....
The cutter is off from perpendicular to the bed by 0.13 degrees. That should be good enough. I could dial it in, if need be.
Will try another test with new settings (Female - 0,300" flat / Male - 0.150" start and 0.150" flat) tomorrow.
I'm having a hard time understanding how my setting (Female - 0.300" flat / Male - 0.200" start and 0.100" flat) could results in the gaps I'm seeing. Drew it up in CAD and it's such a forgiving method.
Very interesting issue. Always amazes me what one learns from problems.
Its a full moon, back out to the shop :D
Greg J
Model of CNC Machine: MechMate #13 -It's a workhorse, LOVE IT!
Postby FixitMike » Thu Mar 24, 2016 7:47 am
Greg: I would recommend a male start depth that is only slightly less than the female flat depth. the difference is an internal gap, possibly for excess glue. A larger difference means you will have an internal hollow of that depth.
FixitMike
Postby Greg J » Thu Mar 24, 2016 1:47 pm
Thanks FixitMike,
That's what been bugging me. I agree with what your saying. My setting (Male - .200" start / .100" flat) should be working. The Female is set at .300" flat.
If I make the Male start .250" and the flat .050", then I will have a small gap between parts.
I'm gonna run into the hardware store and get some CA glue. Make up several test inlays and slice apart to see what the heck is going on.
FYI: when I make an inlay with a straight bit (1/4" end mill), its perfect. Maybe the X and Y axis is fine and the Z axis is acting up . . . . . . . . . hmmmmm
Greg J
Postby scottp55 » Thu Mar 24, 2016 3:46 pm
Show pics when you slice them.
I only dissected one when it was clamped crooked, so no good for real world testing.
GMH
scottp55
Postby Greg J » Fri Mar 25, 2016 12:08 am
Had to glue up some more inlay material and cutting blocks first, but here's the first test
Star pattern, Female - Start = 0.000", Flat = 0.300" / Male - Start = 0.200", Flat = 0.100"
Fits like a glove. No 0.100" gap. Interesting.
Attached is the VCarve file. I save as 4 cut files. 1 female clearing (1/4" end mill). 1 female vbit. 1 male clearing (1/4" end mill). and 1 male vbit.
What the heck am I not understanding?
Star Pattern.crv
(261 KiB) Downloaded 208 times
Greg J
Postby Mobius » Fri Mar 25, 2016 12:45 am
What are you using for hold downs for the male piece? How thick is the original material? Is it possible that the male piece is pulling up, warping or otherwise moving while it is being cut? This would explain why only parts of the cut are not lining up properly. And why your thicker, less detailed star worked better.
Connor Bredin
www.distinctive-concepts.ca
Mobius
Postby Greg J » Fri Mar 25, 2016 12:55 am
Mobius,
For the Elk Inlay, I'm using 1/2" thick walnut end grain. I make up an end grain block and slice off 5/8" thick pieces and glue up. Sand down (drum sander) to 1/2" thick inlay material.
I'm holding the inlay material down with screws and clamps.
what I don't understand with the star test, is why don't I have a 0.100" gap?
Greg J
Postby Greg J » Wed Mar 30, 2016 3:07 am
Not a 100%, but about 95%. Still some small gaps. Could have played with different settings, but just ran out of time. Overnighting to WY for fund raiser.
Basically, everything, the base material and inlay needed to be flat. I thought that the drum sander was flat enough, but it wasn't. Used end mill and milled every surface flat and parallel to the cutter.
More to come.
Greg J
Postby lfinsr57 » Mon Jul 04, 2016 2:53 am
I've tried this process a couple of times with limited success, mostly because I haven't focused on it. But I now have a project I want to do using the method. The thought crossed my mind about using the "model position in material" instead of changing the "start depth." It's probably the same result but it's less confusion for me. Any reason why using the "start depth" value in the "model position in material" wouldn't work?
lfinsr57
Model of CNC Machine: Home built
Postby Paul Z » Mon Oct 31, 2016 8:31 pm
10 years and 1/8 million hits. How time flies.
Paul Z
Postby scottp55 » Mon Oct 31, 2016 11:30 pm
Only when you're having fun Paul! :) :)
THANKS!
GMH
scottp55
Postby Xxray » Tue Nov 01, 2016 3:16 am
Monster thread, will take a while to digest some info.
I have been trying to think up ways to maintain sharp corners, looks like the info is right here if I can translate it to my brain.
Doug
Xxray
Postby Xxray » Wed Nov 02, 2016 6:22 am
Been browsing through the thread, about page 5 or so reference is made to a pdf instruction document, haven't been able to find it is it still here somewhere ?
Doug
Xxray
PreviousNext
