Lets say I draw acircle and want to rotate 20 degrees and make 9 copies.. What would be the easiest way to do this .. I see Mirror object but nothing under roataion copy..
Comments please.
Cheers Chips
Roatate and Transform Geomery functions??
- dighsx
Do you mean you want to make 9 copies that are each rotated 20 degrees from the last copy? So starting at 0 you'd have 20, 40, 60, 80 and so on? If this is the case I'd just copy and rotate each one off of the last copy. Maybe someone can think of a quicker way?
Take it easy.
Jay (www.cncjay.com)
