Keyboard Shortcuts and Icons
Postby dighsx » Fri Jul 28, 2006 10:51 pm
Been working on a cheat sheet that has all the keyboard shortcuts and program icons. Here's what I have so far, take a look and let me know if I missed any shortcuts. Or if there's some other useful information I should put on it.
VCPro_Shortcuts.pdf
(143.09 KiB) Downloaded 660 times
Take it easy.
Jay (www.cncjay.com)
dighsx
Re: Keyboard Shortcuts and Icons
Postby mark296 » Sat Jul 29, 2006 1:12 am
dighsx wrote:Been working on a cheat sheet .
Very nice, Thank you.
mark296
Postby Paco » Sat Jul 29, 2006 4:29 am
Good work Jay!
Don't forget:
Node edit mode:
-D (pointing a span) = delete span... while D (pointing at a node) = delete that node.
-P (pointing a node) = make that node the start point... as long as it is one end of a open vector or a node of a closed vector.
Paco
Postby dighsx » Sat Jul 29, 2006 11:42 am
Thanks Paco, I've updated the sheet.
Take it easy.
dighsx
Postby Warren » Sat Jul 29, 2006 2:40 pm
Hi Jay,
Just noticed a couple of mods you need to make on your "Cheat Sheet" and "How to's"
Shortcuts in Drawing Mode.
"S" key does not scale now. "S" is only smooth/unsmooth point.
"P" key does not pan.
I tried to investigate to see if Brian had changed this to another key function, so I first tried Ctrl-P. That didn't work so tried Alt-P and the pan icon appeared.
I thought that was it so I de-selected and tried again.
If you just select Alt-P it doesn't work. You have to do Ctrl-P, then Alt-P. !!
Pressing the "R" key does rotate. But if you are in node edit, placing the pointer over a vector and pressing "R" does not remove that vector. (Mentioned in Custom Form Tools, Step 6.) Now "D" to delete only.
You havn't been finishing off all your Sam Adams and Homebrew Stout while you were compiling these have you? (hehe)
That's all for now, but I must say, you have performed an excellent task.
Cheers,
Warren.
Warren
Model of CNC Machine: Router
Postby dighsx » Sat Jul 29, 2006 3:23 pm
Ok Warren made the changes to the cheat sheet and I'll update the how-to and faq stuff too.
Thanks for reviewing this stuff. You start to go cross-eyed trying to find all the combinations of keys in different modes. Maybe I should be drinking while I'm writing these..
Take it easy.
dighsx
Postby Les_linton » Sat Jul 29, 2006 4:31 pm
Excellent job Jay.
My only comment would be that for those of us that are slightly more "mature" than others.... (I will never admit to getting older) the font on the Shortcut page is a might small.
I printed it off onto a piece of card stock and it makes it pretty handy.
Thanks again,
Les
Les_linton
Model of CNC Machine: ViperX7
Postby dighsx » Sat Jul 29, 2006 6:20 pm
That's funny you say that Les. I made a version for me with the first page landscaped so it's a lot bigger.
VCPro_Shortcuts_LS.pdf
Heres a landscaped version with larger text.
(141.66 KiB) Downloaded 499 times
Take it easy.
dighsx
Postby Les_linton » Sat Jul 29, 2006 6:47 pm
:D
Excellent Jay, that sure to the squint out of shortcuts.
Les
Les_linton
Postby Colin P F » Sat Jul 29, 2006 10:39 pm
:D Good Work Jay
That is much better, Thanks for putting in the extra work.
Cheers,
Colin
Colin P F
Postby Warren » Sun Jul 30, 2006 11:48 am
Sorry Jay, :oops:
I said,
I am afraid I got this wrong.
If you press Ctrl-P it does switch you into pan mode. But the pan icon did not appear until I moved the mouse.
Maybe I too should be drinking while I'm writing mine. :)
Warren
Postby Burchtree » Sun Jul 30, 2006 12:27 pm
Hi Jay
I can’t seem to download the chart, all I get is a small square in the upper left hand corner.
Dan
Burchtree
Postby dighsx » Sun Jul 30, 2006 1:05 pm
Not a problem Warren, I've updated both files.
Dan, Tony was having problems too. Is anyone else having troubles downloading the files? I'll attach a zip file that contains both cheat sheets. Let me know if you can or can't get this.
VCPro_shortcuts.zip
(209.02 KiB) Downloaded 485 times
Take it easy.
dighsx
Postby Bill S » Sun Jul 30, 2006 1:14 pm
Yes Jay,
I have the same problem
Regards
Bill
Bill S
Postby Bill S » Sun Jul 30, 2006 1:15 pm
Ok Jay,
I replied before I tried your zip file
Cheers
Bill
Bill S
Next
