Let me start with the end goal and then ask how do I get to that point. I have a rectangle with lines spaced out every so often from top to bottom that needs to be a specific depth and then cut 15 degrees up to daylight on each side of the line so when its all cut there is a V shaped groove centered on every line that is 30 degrees. Is there a good 30 degree wood cnc bit that I could just run straight down that line to that depth or can I make this worth with a smaller bit? I'm open to options, I have been doing this on the table saw with a jig but I'm always looking for a way to use the cnc for my projects more often.
Thank you.
V Groove
- Timber Wolf
- Model of CNC Machine: CNC Shark HD4
Re: V Groove
Centurion makes a 30 degree V bit.
- scottp55
Re: V Groove
Also Drillman1's Kyocera;
https://www.ebay.ca/itm/30-degree-angle ... SwPc9W0zMi
We replaced our Vortex with it, and cut quality was the same when tweaked....Not quite as fast as the Vortex liked, but it sounds good for your application?
Welcome!!
Welcome!!
R.N.
R.N.
Re: V Groove
There might be an easier way but the only way to do it with a smaller bit that I can think of is to use the vcarve toolpath. That would involve a little maths because you would need to draw a rectangle that was the required finish width & length rather than one vector to cut on.
Wat sort of depth are you cutting to, you don't say in your original post
- Timber Wolf
Re: V Groove
Sorry it’s going to be just under 3/4” deep so I could do the math or sketch it up from a profile view and determine it that way with a rectangle. I may play with that today and see. Thanks.
