Importing STL for 3D project
Postby Loesch » Fri Jul 05, 2019 3:20 pm
I'm getting around to trying a 3D cut for the first time. I have a STL file of a wine barrel with grapes and leaves that my wife wants cut. When I view the original file in a STL viewer, it looks fine and matches the JPG that came with it. However, when I import the file to Vcarve Pro, I'm missing many portions of the design and can't figure out why. Anyone with experience in 3D carvings have any suggestions?
Original File
After Importing
Loesch
Model of CNC Machine: Stepcraft V2-600
Re: Importing STL for 3D project
Postby Adrian » Fri Jul 05, 2019 3:23 pm
Where did you set the "Zero plane position in model" slider on the import form? If it was set to the centre I could see it causing that problem.
Postby Loesch » Fri Jul 05, 2019 4:17 pm
I thought of that and moved both of the two sliders (shape height and base height) up and down, but it didn't reveal any additional detail in the model.
Loesch
Postby TReischl » Fri Jul 05, 2019 5:10 pm
Loesch wrote:I thought of that and moved both of the two sliders (shape height and base height) up and down, but it didn't reveal any additional detail in the model.
Pay attention to Adrian, he said "zero plane position" not "shape height and base height". He was referring to THIS slider when you import the model:
If you do not set that slider correctly when IMPORTING there is nothing you can do to fix it later on.
Here is your model when the slider is set correctly when IMPORTING:
http://www.tedreischl.com
Low Profile CNC Router Vise
Postby Loesch » Fri Jul 05, 2019 6:59 pm
That was what I was missing. Thought it was set by the model and evidently didn't try changing it. I did as Adrian and TReischl suggested and now I have the full detail I needed. Thank you both for the education.
Loesch
Postby TReischl » Fri Jul 05, 2019 7:52 pm
BTW, I have not had a chance to cut that model yet, if you get a chance post it up when you are done in the Gallery section. Would love to see it for real.
