Clock Face Hour Marking
Postby cjmcdonald » Mon Jun 03, 2019 3:02 pm
I am interested in creating a clock design using VCarve. Is there a way to determine the points in a circle that would represent the hours of a clock face? In other words, is there a way to plot a mark every 30 degrees where the hour would be?
Thank you.
cjmcdonald
Model of CNC Machine: ShopBot
Re: Clock Face Hour Marking
Postby Adrian » Mon Jun 03, 2019 3:25 pm
It's come up few times on the forum. This is one thread - viewtopic.php?f=2&t=3808
As with many things in VCarve there are several ways of doing it but most will use the Circular Copy tool align the numbers from there.
Postby sharkcutup » Sun Jun 16, 2019 12:13 am
Face Numbers Setup.crv
(79 KiB) Downloaded 49 times
Here ya go have fun!
11" Circular clock face on 11.25" x 12.0" material. File can be resized in Job Setup Area under Design Scaling.
Used a profile line at 12 o'clock then used circle copy the line 12 times then placed numbers on the lines then removed lines for clock face.
Sharkcutup
Facebook: Hogan's CNC Crafts
Website: www.hoganscnccrafts.com
V-Carve Pro 9.517
sharkcutup
