Change the increment of movement
Postby skieva » Sun Jun 02, 2019 12:43 pm
When using keys to move vectors, how do the shift and CTRL keys change the increment of movement?
skieva
Model of CNC Machine: X-Carve
Re: Change the increment of movement
Postby skieva » Sun Jun 02, 2019 1:55 pm
Found the answer.
Arrow Key alone .0156 per click
Shift/Arrow key .0786 per click
CTRL/Arrow key .0036 per click
skieva
Postby jam1962 » Sun Jun 02, 2019 2:00 pm
F4 will let you adjust the nudge distance.
Jay Morris...
jam1962
Model of CNC Machine: Self built 36x25x7
Postby Adrian » Sun Jun 02, 2019 2:06 pm
Only at the zoom level you're currently on. The amount of movement is a factor of the level you're zoomed into not a fixed amount. Ctrl will reduce the relative distance and Shift will increase it.
If you want to move by a fixed amount press the F4 key to bring up the Snapping Options and set the Fixed Nudge Distance. Pressing Ctrl-Shift-Arrow will then move by that exact distance. Setting the Fixed Nudge does not affect the Shift-Arrow or Ctrl-Arrow combinations.
Postby skieva » Mon Jun 03, 2019 3:29 am
At what point do you hit F4? I am in the 2D view, I have selected a vector to move, hit F4, and nothing
skieva
Postby gkas » Mon Jun 03, 2019 4:45 am
Adrian wrote:If you want to move by a fixed amount press the F4 key to bring up the Snapping Options and set the Fixed Nudge Distance. Pressing Ctrl-Shift-Arrow will then move by that exact distance. Setting the Fixed Nudge does not affect the Shift-Arrow or Ctrl-Arrow combinations.
The F4 key only brings up the SNAPPING OPTIONS DIALOG. You can enter the distances you would like to move into the dialog.
P.S. Thanks Adrian... I forgot that dialog was there :?
gkas
Users browsing this forum: Google [Bot] and 6 guests
