Real Size Printing?
Real Size Printing?
Postby johnelle » Mon Apr 29, 2019 3:07 pm
I am using Vcarve for a bandsaw project which means I have to have the output print at 100% scale. Everything I have tried (including Adobe .pdf output) is scaled. I have tried poster print, orientations, etc. It always scales it at some random amount.
Am I going to have to use Illustrator for this project? I hope not because it takes hours to learn enough Illustrator to do a simple design.
johnelle
Re: Real Size Printing?
Postby adze_cnc » Mon Apr 29, 2019 5:04 pm
This gets asked often. For the the last such thread: https://forum.vectric.com/viewtopic.php?f=18&t=31670&p=229021&hilit=pdf#p229021
Adrian's final comment might be what you are looking for.
Postby Rcnewcomb » Mon Apr 29, 2019 6:32 pm
If you have a printer that understands HPGL then the Generic HPGL post processor may work for your purpose.
Postby Adrian » Mon Apr 29, 2019 6:53 pm
johnelle wrote:I am using Vcarve for a bandsaw project which means I have to have the output print at 100% scale. Everything I have tried (including Adobe .pdf output) is scaled. I have tried poster print, orientations, etc. It always scales it at some random amount.
Check your settings in the PDF reader you're using as you should be able to print at 100% scale no problem with a PDF file exported from VCarve. A common issue is overlooking margin/header/footer settings.
Postby ngh » Tue May 07, 2019 10:22 pm
My methodology to print an actual size representation on my inkjet printer:
I use is LibreOffice Draw (part of the free LibreOffice suite) and print in 100% scale.
My small CNC is about A4 sized (200 x 300mm) or (12 x 8 inches), so a normal A4 page is very close.
I export the vectors as a .svg file out of VCarve.
Then I open the .svg via LibreOffice.
I format my page to the exact sizing I am using (200 x 300mm).
then I print at 100% scale and no margins.
So far everything has lined up perfectly to my actual cuts.
This probably will only work for the smaller size jobs.
Hope this helps.
ngh. 8)
ngh
Model of CNC Machine: Shark Pro
Postby ezurick » Wed May 08, 2019 8:10 am
Sorry for the dumb question, but s a newbie I'd like to know.... why would you do this? I mean if you have a lettering carved on wood from vcarve... why would you need a inkjet print of it? Just curious.
ezurick
Postby martin54 » Thu May 09, 2019 9:43 pm
ezurick wrote:Sorry for the dumb question, but s a newbie I'd like to know.... why would you do this? I mean if you have a lettering carved on wood from vcarve... why would you need a inkjet print of it? Just curious.
The OP was asking about a bandsaw project so something that has been designed in Vcarve & then a paper template printed which is then stuck on the piece of material for bandsaw cutting :lol: :lol: :lol:
Postby ezurick » Sat May 11, 2019 11:06 am
Aah! got it. Guess I missed about the bandsaw. Thanks for explaining Martin.
ezurick
Users browsing this forum: No registered users and 7 guests
