double sided project link objects
Postby jbanti » Wed Mar 06, 2019 6:37 pm
Hello,
i have a problem, i make a double sided Project and i need to link the draws of the two faces:
i have a circle in the top face and in the bottom face a square. i want to link together because i need to move the circle depending of the Wood.
do you know how do it?
picture of the two faces project
thanks
jbanti
Model of CNC Machine: custom cnc
Re: double sided project link objects
Postby highpockets » Wed Mar 06, 2019 7:09 pm
At present there is no "lock" feature between sides. What I do when I need to move object on the top side in unison bottom side I temporarily move the objects on the bottom side to the top, select all objects to move then move the objects back to the bottom side.
It's not perfect, but it works.
Postby garylmast » Wed Mar 06, 2019 7:55 pm
Another way is Create of Vector boundary around the square, then move both square and vector to the new location. Copy the vector to the other side, then use the Center Objects (center object on last selected object), by selecting the circle first then the square vector last.
Gary
garylmast
Postby jbanti » Fri Mar 08, 2019 6:59 pm
thanks i tested it. it's not perfect but is good :-)
jbanti
Users browsing this forum: Google [Bot] and 5 guests
