beveled edge table top
Postby duster » Wed Mar 13, 2019 2:35 am
I'm trying to figure out how to machine a 45 degree beveled edge onto a 2.25" thick oval table top.
I haven't been able to find anything that explains how to achieve this detail... Any help would be appreciated!
duster
Model of CNC Machine: Shop Sabre Pro 408
Re: beveled edge table top
Postby highpockets » Wed Mar 13, 2019 2:44 am
How big is the oval table top?
Are you creating it on your CNC or does it already exist?
How deep do you want the 45° bevel edge to be?
Postby duster » Wed Mar 13, 2019 2:50 am
The top will be 40 x 80. The bevel needs to be the entire 2.25" height.
duster
Postby duster » Wed Mar 13, 2019 2:53 am
The top will be machined out of a larger blank. All I've done so far is to glue up and surface the blank.
duster
Postby rscrawford » Wed Mar 13, 2019 2:53 am
Watch the tutorial on the moulding tool path. I find it more useful than modelling and finish tool path in Aspire. Will give you the best finish, unless you have a large 90 degree v-bit and can just use profile cuts!
You might even be able to use a 90 degree V-bit with the moulding tool path to get the smoothest result, using a 1/2" ballnose or end mill for the roughing pass to give you clearance for the smaller v-bit.
Russell Crawford
rscrawford
Postby highpockets » Wed Mar 13, 2019 3:48 am
+1 for using the Moulding Toolpath
Postby duster » Wed Mar 13, 2019 4:38 am
Ok, thanks! I'll check out the moulding tutorial. The drawing posted is what I'm trying to do.
I think I'll try a smaller test on foam before I commit to this big slab of walnut...
duster
Postby duster » Thu Mar 14, 2019 3:34 am
Ok, I watched the moulding tutorial. However, I couldn't see how this was going help me produce
the beveled edge I'm trying to get on the oval top. I seem to be missing something. I can draw the
oval, and it's offset edge. But how do I get to the beveled edge?
duster
Postby highpockets » Thu Mar 14, 2019 3:46 am
duster wrote:Ok, I watched the moulding tutorial. However, I couldn't see how this was going help me produce
If you look close at the pictures in my post there's the offset rail and a 45° profile vector.
Postby duster » Thu Mar 14, 2019 4:06 am
I guess what I'm failing to understand is how to establish the 45 degree profile vector.
What steps do I take to get that?
duster
Postby highpockets » Thu Mar 14, 2019 4:25 am
Using the Create Line tool draw a vector at a 45° angel 3.182" long. Or with out math, draw a 2.25" x 2.25" rectangle then using the Create Line tool draw a line for corner to corner.
Postby duster » Thu Mar 14, 2019 6:04 am
Ok, that makes sense. I'll give that try. Thanks!
duster
Postby adze_cnc » Thu Mar 14, 2019 4:36 pm
Sort what John said except different: start to draw a line then enter 2.25" in dx and 2.25" in dy then click add point. Let the program figure it out.
Steven
Creep, crawl, toddle, walk, run
Best answer for a simple question? Help > Help Contents
adze_cnc
Postby martin54 » Thu Mar 14, 2019 9:28 pm
highpockets wrote:Using the Create Line tool draw a vector at a 45° angel 3.182" long. Or with out math, draw a 2.25" x 2.25" rectangle then using the Create Line tool draw a line for corner to corner.
Or you could draw a 2.25" square :lol: :lol: :lol: :lol: :lol:
Postby highpockets » Thu Mar 14, 2019 9:43 pm
Next
