TYPES OF HOLDDOWNS
TYPES OF HOLDDOWNS
I seem to always be trying to figure out a better way to hold the material down on my cnc router.
Could a number of people respond and describe the ways they hold down work and if they have found a particularly good method.
Tom
Tom
- Perry
- Model of CNC Machine: Modified Shopbot PRT96
Holddowns
Hi tommoser!
The method I typically use for the bulk of my signs is good old fashioned screws placed around the perimiter (which has been calculated a scrap). I have also used: cam locks I made myself, vacuum hold down table and on a two sided sign I do all my machining on one side, cutout the profile ith a 1/4" spiral cutter, flip the sign over, add 1/4" shims to hold in place. This is the same method I use to hold signs while I cut keyholes for mounting.
Hope this helps.
Hope this helps.
- dighsx
Two words, carpet tape, for 90% of all the stuff I cut I use carpet tape and then I lock my clamps down around the work piece for insurance. I've used some normal two-sided tape for some small stuff but I've found the carpet tape works the best. Most of the time I have to use a screwdriver to get the piece unstuck from the table when I'm done.
Here's a shot of what I'm talking about. The block of wood is taped down and I just put the clamps there for insurance.
- (349.09 KiB) Downloaded 1100 times
Take it easy.
Jay (www.cncjay.com)
- RoutnAbout
I also use doubled face carpet tape about 80% of the time and either use drywall screws with a squaredrive instead of the phillips drive ( the screw body it self is made different and usually harder to twist the heads off ). I usually don't use the tabbing with this method unless I can't be at the machine while cutting. I'm also reading and researching information for a vaccum hold down system.
Don
Don
Vacuum Pods
We bought pre-made vacuum pods from Nappy Products:
http://www.nappyproducts.com/vacuum_pod ... terial.htm
Now we buy scrap PVC or phenolic from a local outfit, drill two connected holes and apply some gasketing material from All-Star Adhesive: http://www.allstaradhesives.com/products.htm
and insert a vacuum hose connector.
Instructions about vacuum pods and such are available here (scroll down on the page once it loads):
http://www.baycraftdesigns.com/Shopbot.html
Vaccuum pucks
I read on the Shopbot forum once about someone using plastic decking material such as Trex to make pucks. I haven't tried it yet but I plan to.
- Wemme
Re: Vacuum Pods
Do you need a filter to stop dust and crap from ending up in the vacuum system?Rcnewcomb wrote:We bought pre-made vacuum pods from Nappy Products:
About 5 years ago I put a little filter on a small vacuum pump I have been using for 15 years. Two weeks ago as I was installing my new ShopBot and de-comissioning my old homemade CNC machine I saw the filter and wondered how it (the vacuum pump) was still functioning. The front end of the filter was totally full. Pump still works fine. Filters are good, but check them every once in awhile. I used it intermittantly but obviously more than I thought!
I use two Fein Turbo III's connected to a T and a 4 zone full bleed vacuum table for large sheets. I also use 1/2" Baltic Birch with All Star Gasket for smaller items that tend to not want to lay flat and move on the large vac table. With the center cut out of the 1/2" ply and gasket around the outside, just inside of the cut, I get super holding and quick cycle time between parts.
I also have a two stage high vacuum pump that I hold bowls on my wood lathe that is available to the CNC with pucks or pods. They also work super good. I have a square of Corian that I lay on the CNC and let the pucks stick to that. I still use my Turbo III's to hold the Corian down to the CNC.
I have not used a screw for a long time now. Nothing wrong with them! I am sure I will use them again.
Some jobs are run with a stop screws to the bed and I use two wedges against another stop. A light tap of the hammer and the wedges are tight.... another tap in the other direction, they are loose.
I am located at about 550' above sea level. Remember as you go up, you have less air to hold your parts down. I expect my setup would not work for someone in Denver, Co. for example.
I too am still looking for the magic bullet of hold downs but till that comes along, my two vacuum systems work real good for me.
Hope some of this helps.
Ed
Ed
- dighsx
In another life I did work for a company that manufactured automotive parts. One thing they had that I always thought was neat was a magnetic holding system for automated milling. These huge blanks would ride along a conveyor and stop at different stations to get machined. At each station a rather large electromagnet would flip on and the part would lock in place in these clamps. These electromagnets were quite powerful, they tool a block of steel that had a warp in it and put it on and flipped the switch and you could see it bend it down.
One thing that occurred to me while standing next to these magnets is should I be worried about how close I should really get to these things. Like they might be limiting my chances of producing future generations if you know what I mean.
Take it easy.
