Page 1 of 1
Is their a way to Mirror a 3d file
Posted: Mon Sep 17, 2018 2:26 am
by rjgodboout
I am ready to cave an image on a double door cabinet. My neighbor would like a left and right leaning bear hugging a girl, STL file.
Is this possible. If so how??? I've only had my machine for a few months and I"m pretty impressed. I've learned to be careful with the software as it can bite you.
Thanks, Bob G
Port Charlotte Fl
Re: Is their a way to Mirror a 3d file
Posted: Mon Sep 17, 2018 2:42 am
by highpockets
Select the model and use the Mirror Tool on the Model Tab.
Posted: Mon Sep 17, 2018 5:49 pm
by gkas
The mirror tool is only available for 3D stl in Aspire, not Vcarve. Vcarve will not mirror the stl. Following the one stl in Vcarve rule?
Posted: Mon Sep 17, 2018 6:33 pm
by Adrian
gkas wrote:The mirror tool is only available for 3D stl in Aspire, not Vcarve. Vcarve will not mirror the stl. Following the one stl in Vcarve rule?
Works ok for me in VCarve. The mirror tool is on the drawing tab not the Modelling tab and will mirror an STL.
Posted: Mon Sep 17, 2018 7:18 pm
by mtylerfl
gkas wrote:...Following the one stl in Vcarve rule?
You can have as many duplicates of that one STL file in VCarve as you want. Mirrored, resized, rotated, arranged - whatever.
Posted: Mon Sep 17, 2018 7:26 pm
by gkas
Good to know. I saw that Aspire had a mirror tab in modeling, but Vcarve didn't. I ASSumed that the Vcarve one wouldn't mirror stl. My mistake.
Posted: Mon Sep 17, 2018 7:29 pm
by mtylerfl
Here's an example of an imported (and duplicated) STL model into VCarve. Piggies galore!
Posted: Mon Sep 17, 2018 7:35 pm
by mtylerfl
gkas wrote:Good to know. I saw that Aspire had a mirror tab in modeling, but Vcarve didn't...
To Mirror QUICKLY:
1) Select the model
2) Press Ctrl+Shift+H to mirror/duplicate horizontally
3) Press Ctrl+Shift+V to mirror/duplicate vertically
(To mirror anything without duplicating - select any item and just press H or V)
Posted: Mon Sep 17, 2018 7:43 pm
by rjgodboout
highpockets wrote:Select the model and use the Mirror Tool on the Model Tab.
Highpockets, Thank you.
Yes you can mirror in VcarvePro 9.0
RJG
