Text Inlay
Text Inlay
Postby Rburke » Thu May 31, 2018 1:31 am
I am working on a project which has an image and text inlay. The text is Cambria and is .41 inches high. The way Vectric described VCarve inlay worked fine for the image but when I tried it with the text the pocket side went about .1" deep while the insert went the full .2". The insert with the text did not come to a point so it did not fit in the pocket. I am using a 60 degree .25" V bit. I have just taken it down to .25" in depth and am about to see if it will fit. The top is not yet shaped to an edge but I will try it anyway. If it does not fit I will switch to a 60 degree .5" bit and cut deeper. Am I on the right track or is there a better way to approach text inlay?
Rburke
Model of CNC Machine: Stinger 1
Re: Text Inlay
Postby Rcnewcomb » Thu May 31, 2018 1:38 am
Can you post your CRV file?
Re: Text Inlay
Postby Rburke » Thu May 31, 2018 9:41 pm
]Thanks, seems to have me a little stumped.
Bloody Arm Text Insert Pocket.crv
(1.92 MiB) Downloaded 107 times
Bloody Arm Text Insert Finish.crv
(1.59 MiB) Downloaded 92 times
Rburke
Re: Text Inlay
Postby Rburke » Thu May 31, 2018 10:18 pm
I think I see what I did. On this text insert I had a start depth of 0 and a flat depth of .2 Looks like I inadvertently applied the values for the pocket. It now looks more like it should on the preview. Anyway, try, try again. I would still be interested in your advice if you are willing to look at the files I posted. I am just getting started with inlay and don't know what I don't know.
Rburke
