Thanks in advance for any light you can shed on my questions:
I'm using VCarve desktop 8.5. I produce a lot of hand drawn images that I then scan, save as a JPEG and bring in thru Import Bitmap for Tracing and at that point they are all single line images. Then when I use the Trace Bitmap tool all the lines appear as double lines. There is always a great deal of unwanted specs that need to be removed thru Node Editing.
My two main questions are: How do I eliminate the second double line and then how do I make the single line bolder so I can have it cut deeper?
Appreciate any and all suggestions.
