Directionally Challenged
Postby offcenter » Tue Mar 20, 2018 2:49 pm
When drawing a line by typing the angle and length, the zero angle begins at "east" and increments counter-clockwise. Is it possible to change those settings? I used Autocad for years, and unit direction was a user defined setting. I can't find any info on this in VCarve.
offcenter
Model of CNC Machine: Axiom
Re: Directionally Challenged
Postby adze_cnc » Tue Mar 20, 2018 4:40 pm
You are right to put east in quotes. But really all makes sense if you remember that we are dealing with mathematical vectors and not a the metaphor of a comapss.
Which see:
https://chortle.ccsu.edu/vectorlessons/ ... h05_2.html
adze_cnc
Postby FixitMike » Tue Mar 20, 2018 6:09 pm
But why does the icon for the rotation tool show the arrow in the negative angle direction ?
FixitMike
Postby IslaWW » Tue Mar 20, 2018 6:13 pm
I don't believe there is one. Vector geometry follows Cartesian coordinate angles which have zero degrees positive in X to the right (your east) and increasing counterclockwise. This is one of the main differences between "paper" and machining. On paper there is no negative impact for user defined angles. Not so for machining vectors.
Gary Campbell
CNC Technology & Training
GCnC411 (at) gmail.com
IslaWW
Postby ger21 » Tue Mar 20, 2018 7:22 pm
offcenter wrote: I used Autocad for years, and unit direction was a user defined setting.
If you use the default settings in AutoCAD, the rotation is the same, which is the correct way. :D
ger21
Postby offcenter » Tue Mar 20, 2018 8:33 pm
adze_cnc, I put east in quotes only for the question I posted.
Sometimes, I like to enter lines by a starting point, the angle and length of each line. I'm getting used to 90, 0, 270 and 180 (north, east, south and west respectively), but just thought that if there was a way to change it, I'd do it. I've found other shortcuts or settings in VCarve that have made design easier and was hoping there would be one for this. If not, no big deal.
offcenter
Users browsing this forum: Google [Bot] and 9 guests
