Modify material position
Postby cingolo » Fri Jan 26, 2018 3:34 pm
Good afternoon
How can I change the position of the model in the workipiece once the project has been created? :?:
I do delete all and restart? :(
thanks
Remenber ! A good sharp for a good mill!
cingolo
Model of CNC Machine: home made project
Re: Modify material position
Postby joeporter » Fri Jan 26, 2018 4:24 pm
Double click on the model and you will see a set of "Handles" grab the center one and move the model where you want it. You can also resize the model up or down with the upper left handle and hold "Shift" and stretch or shrink...joe
Original Position
New Position
Larger Size
joeporter
Postby Adrian » Fri Jan 26, 2018 4:42 pm
If you want to move it precisely you can also press the M key and enter absolute or relative co-ordinates.
Postby cingolo » Sat Jan 27, 2018 12:58 pm
thank you at all
the last question; if I want to move on Z axis? :?:
see image
thanks
my problem
cingolo
Postby Adrian » Sat Jan 27, 2018 2:00 pm
Z is basically the thickness of the part. You can't do undercuts so you can't have a piece off the base.
Postby cingolo » Sat Feb 03, 2018 6:16 pm
Thank you at all! :D
cingolo
