The "Ultimate Tabletop Machine" for Woodworkers
Postby IslaWW » Sun Jan 21, 2018 3:24 pm
There are a lot of guys here that use CNC machines for woodworking or signmaking and I would like to know what some of your "wish list" features would be. Most currently manufactured table top (~24 x 36) machines use NEMA23 motors and smaller components in able to fit a price point for the size class. This forces successful hobbyists and commercial users to buy larger machines than their material dictates to obtain higher end features than tabletops offer. This uses up precious real estate in the shop, no matter if it is commercial or non-commercial.
For example, this machine: https://youtu.be/qtzkAExTA00 was purchased by a signmaker that sells product online from his home business. After 3-4 months of use (and his Christmas rush) he sent an unsolicited letter full of praise for the machine and enumerated his production increases. I had offered up (pre sale) that even tho he currently had a larger machine, that these features would allow him to double or triple his output. He has happily informed me that those results were underestimated. His machine, loaded with function and feature, costing 3-4 times what a typical machine that size does, will pay for itself in 6 months.
So, for those that are either small commercial or discriminating hobbyists and wish to have a small footprint machine, with "big" features that would allow longer duty cycles, faster cutting............ What would those features be?
Gary Campbell
CNC Technology & Training
GCnC411 (at) gmail.com
IslaWW
Re: The "Ultimate Tabletop Machine" for Woodworkers
Postby SteveNelson46 » Sun Jan 21, 2018 5:44 pm
That's a great question, Gary. If we can get some feedback I think that it will be useful information to anyone who is looking to purchase a machine.
SteveNelson46
Postby Rcnewcomb » Sun Jan 21, 2018 8:52 pm
The 6 tool ATC is perfect. What is the Z clearance?
I like that it is using WinCNC.
Wish list...
A rotary axis option would be great.
An option of 24"x48" would be nice.
Option for either Vacuum and/or T track holddown.
Postby mezalick » Sun Jan 21, 2018 9:11 pm
I agree,
I think a vac table top would be nice...
~M
Michael Mezalick
https://carveddetails.com
mm@mezalick.com
mezalick
Postby ElevationCreations » Sun Jan 21, 2018 9:32 pm
In addition to the other suggestions:
120 VAC Operation option
Ability to be taken down stairs into the basement
2x3 or 2.5' x 3.5' work area would be sufficient
Z movement of 6"
Designed to easily add an enclosure to help mitigate noise
ElevationCreations
Model of CNC Machine: Shapeoko SO3 XXL & SO3
Postby ger21 » Mon Jan 22, 2018 12:37 am
You can't run a decent spindle on 120V.
ger21
Postby eph210 » Mon Jan 22, 2018 3:07 am
My wish list would include:
Hybrid steppers with feedback
6 inches of gantry clearance and at least 8 inches of Z travel
Ability to clamp items vertically for end machining
HGR25 slides with double bearings on all axes
inboard rotary axis for multisided machining
aluminum T slot table top with the T slots extending 3 inches fore and aft of the cutting area
Air nozzle and mister plumbed to head and controlled in G code
Registration points for removable fixtures
Euan
eph210
Model of CNC Machine: Stinger 1 and Mabel, both with 4 axis
Postby IslaWW » Tue Jan 23, 2018 6:30 pm
Thanks for the replies so far. Almost 300 views and no one else has something on their wishlist?? Forget your checkbook, think with your imagination!!
Gary Campbell
IslaWW
Postby FixitMike » Tue Jan 23, 2018 8:39 pm
Well, if cost is not a consideration, here's some:
Right angle head for machining the ends of long pieces.
Two interchangeable tables--one in work and the other slid out and available to set up next job.
Absolute position encoders with readouts both absolute and relative.
FixitMike
Postby martin54 » Wed Jan 24, 2018 1:48 am
I looked but don't have a wish list for a tabletop machine, mainly because if I had the money then I would be looking at a larger machine, as a signmaker in the UK you really need an 8 x 4 machine or bigger :lol: :lol:
I said on another post that I hadn't actually used my machine for very much sign related work but those jobs I have done have nearly all had to be tilled because I can't cut a full sheet of material :lol: :lol: If I had done more sign work then chances are I would have had to tile a lot more work.
Of course then I would also have to move to a larger unit as well because I simply don't have the space for a larger machine in my current unit :lol: :lol: :lol:
Postby Leo » Wed Jan 24, 2018 3:31 pm
True 4 axis -- seperate driver for rotary axis - not axis swapping
Rotary axis with a brake to lock rotation for "X"-"Y"-"Z" work without putting cutting forces against the drive train.
VERTICAL clamping.
Possibly 5 axis?
Enclosures - for computer, mouse, keyboard
Enclosure - for machine with dust and chip control - sound control
Cabinet - for entire machine, tool drawers, cutter storage
COMPLETE - include computer, all set up
OPERATOR MANUAL - Clear and concise instructions.
Started tooling package - cutters, clamps, etc
Spindle Coolant tank - baffles, filters, covered(sealed)
NEMA 34?
ER20 spindle
Lighting - directional (gooseneck)
GOOD - tool touch off
Good looking machine - colors - styling - textures - powdercoat - textures - Anodize (even guys like this stuff)(there IS a female market out there also - lets not forget them)
www.leosworkshop.com
Leo
Postby Gasawdust » Wed Jan 24, 2018 3:37 pm
Quick and good quality “after purchase” support.
Gasawdust
Model of CNC Machine: Fineline 2x4
Postby Adrian » Wed Jan 24, 2018 4:00 pm
A tabletop machine isn't of interest to me as everything I do is 8x4 based however if I was restricted on space and needed a tabletop machine I would want it to be able to perform multiple duties because of that lack of space. So I would want it to be able to replace my vinyl cutter, 3D printer, milling machine, lathe etc. Basically the modern equivalent of those old machines that were a saw table, planer/thicknesser, edge jointer and spindle moulder all in one.
Postby rscrawford » Wed Jan 24, 2018 4:33 pm
On my wish list would be a robotic arm with a 5hp ATC spindle mounted to a 3x5 table. True 5 axis machining for easier furniture parts.
Russell Crawford
rscrawford
Model of CNC Machine: CAMaster Cobra 408 ATC with recoil
Postby 4DThinker » Wed Jan 24, 2018 5:32 pm
Automatic Tool Changer. 4 would be enough for 99.9% of the projects I've done. Needs to be mechanically simple and low cost.
4DThinker
Next
