My design has bumps where I believe it should be smooth. Other parts look great. It is a v3m file from Design&Make. I used a 90 degree bit.
Thoughts?
Bumpy 3D image
- Model of CNC Machine: Shark HD4
Re: Bumpy 3D image
The files are designed to be cut with a 1/8" ballnose bit. Using a 90 degree v-bit could give odd results depending on the stepover.
Re: Bumpy 3D image
A picture would be helpful
What did the toolpath preview look like ? That is always the first place I check
