Sanding blocks
- gkas
Sanding blocks
The other day I was watching Stumpy Nubs extolling the virtues of his new shaper. He was discussing having custom knives made. You also can get custom shaped sanding blocks that match the same profile made at the same time. I thought WOW, I can cut custom sanding blocks with the CNC for any sanding profile I need. I'm going to have to give it a try.
- Model of CNC Machine: Camaster Stinger STV4800
Re: Sanding blocks
Now that is a great idea! I wonder if the blocks will need to have tolerances for different grits? Maybe a finer grit paper is thinner than a courser grit.
Kipp
Kipp
CAMaster Stinger 1
Shopbot PRT 9648
STV4800
Aspire
Cut2d,Cut2dLaser
Shopbot PRT 9648
STV4800
Aspire
Cut2d,Cut2dLaser
- Model of CNC Machine: Homemade
Sanding blocks
Marvelous.
