V Carving on a round handle
Postby olf20 » Mon Jul 24, 2017 12:33 am
Any one have a tip on how to engrave a name on
a round handle. The diameter is 3/8" and the customer
wants their name on it.
It works but the larger letters (Caps) start losing depth.
I have adjusted the start depth a little which improves it.
Thanks for any help!
olf20 / Bob
[color=#8000BF]Heat with corn, Mach3, Bridgeport clone, VcarvePo, Photo VCarve, Craftsman Wood Lathe[/color]
olf20
Re: V Carving on a round handle
Postby dhellew2 » Mon Jul 24, 2017 1:18 am
In the tool path check the box to 'project toolpath onto 3d model'
Dale
Dale
dhellew2
Postby 4DThinker » Mon Jul 24, 2017 2:00 am
You will have to create a model of the handle to use the suggested "map to 3D model" feature.
4DThinker
Postby olf20 » Mon Jul 24, 2017 1:23 pm
Thanks guys. I will dig in to and learn yet another feature
of this wonderful software.
olf20 / Bob
olf20
Postby highpockets » Mon Jul 24, 2017 2:08 pm
Google G code ripper
Postby IslaWW » Mon Jul 24, 2017 2:10 pm
To do this in the best way possible you would want to use a rotary axis with a 3D model of the handle in a rotary setup job and then "Apply Toolpath to 3D Model" as an option on a vcarve toolpath.
Gary Campbell
CNC Technology & Training
GCnC411 (at) gmail.com
IslaWW
Postby 4DThinker » Mon Jul 24, 2017 3:47 pm
You don't need the "Apply to 3D model" step if you are using the wrapping strategy with a rotary axis. You don't even need a 3D model if the handle is a simple cylinder shape. The rotation will take care of cutting the letters evenly around the shape.
4DThinker
Postby IslaWW » Mon Jul 24, 2017 4:14 pm
4d is correct. I had a brain fart thinking the handle was tapered
Gary Campbell
IslaWW
