Okay to use CA glue on vcarve inlays?
sudo
Model of CNC Machine: CNC SHARK HD4
Post by sudo »
Im doing some inlay work and im wondering if using ca glue and activator is a good idea to secure the inlay
This is an ornamental inlay. Has anyone ever tried ca glue and activator vs wood glue on a vcarve inlay?
Thanks in advance.
Re: Okay to use CA glue on vcarve inlays?
Post by scottp55 »
All CA ...1 week-3yrs now no problem. Rockler medium CA.
Have EVERYTHING ready to go and get clamped QUICK!! NOT much time to fuss with things!
Oh, 1 FULL hour or more clamping to the max in my case...usually was removing waste within 3 hours...no accelerator.
FixitMike
Post by FixitMike »
Place matching indexing marks on the two pieces so you can line them up easily for gluing.
Post by Rcnewcomb »
Scott
I admire your work and your willingness to help others
MarkJohnston
Model of CNC Machine: CAMaster MC4848
Post by MarkJohnston »
Scott I to think your work is awesome!!
Thanks for all your post, please keep them coming.
Mark
sudo
Post by sudo »
Thanks for the info.
This might seem like a silly question, but do you use a brush to spread the glue around? Do you just count on squeeze out to spread it around?
Thanks again!
Post by scottp55 »
Using the medium CA, I try to hit top edges of the female evenly, and excess pools at bottom....toothpicks/hibachi skewers to spread..clamp quickly and then invert so excess CA reinforces the waste to be removed.
NO Ca on the male parts....massive clamping FAST.....Record bench clamp works well.
I try for the most minimal gap so flat bottom adds to total adhesion.
Never yet put Ca on the Male Inlay, and it seems to work quite well.
2 reference pencil marks while dry fitted helps a LOT to get the most out of the 16 second open time.
Post by scottp55 »
If doing large areas, break up the pieces with a scroll saw to make clamping faster.
LittleGreyMan
Post by LittleGreyMan »
Rcnewcomb wrote:Scott
+1
Best regards
Didier
W7 - Aspire 8.517
oldlogtrucker
Model of CNC Machine: Cam Master StingerII
Post by oldlogtrucker »
What is CA Glue?
Embroidery - WingsXP
IslaWW
Post by IslaWW »
cyanoacrylate glue aka... super glue or one of its clones
GCnC Control
markevans36301
Model of CNC Machine: shopbot handibot
Post by markevans36301 »
IslaWW wrote:cyanoacrylate glue aka... super glue or one of its clones
