Re: Re: Version 9.0 is here. Upgrade Now!
- stephenr
- Model of CNC Machine: Shopbot PRS Standard 48x96
Is there a way to see the v9 manual and clipart library images before upgrading?
Thank you,
Stephen R.
Thank you,
Stephen R.
- Model of CNC Machine: X-Carve 500x500
I just upgraded from Vcarve Desktop v8.5 to Desktop 9 and I am very happy with all the improvements. But I do not understand why the ability to pull the list of Toolpaths out as a floating window was removed in V9.
In version 8 and 8.5 there was a small button on the bottom right of the screen (to the right of the "Show 2D Previews" and "Solid" check boxes. When that little button was clicked the "Toolpath Control" panel would open and it could be dragged around the screen.
This was very useful when a project had lots of toolpaths and you were trying to group toolpaths with the same tool together for saving.
Is there another way to do this now, or did we loose that little bit of functionality in V9?
Picture of what I am talking about is attached.
I installed the trial for Cut2d v9 and the post processor documentation is still dated 2014. Are there any new features?
I watched the YouTube video called "Cut2D Desktop What's New v9.0" ( At around 34:40 there is a check box option labeled "Project toolpath onto 3D model" near the bottom of the profile toolpath properties section (just below where it shows Home Position and Safe-Z). That area of the display on the trial version is blank. How does this option work? How do I enable the capability?
I expect the video was made using VCarve.kstrauss wrote:I watched the YouTube video called "Cut2D Desktop What's New v9.0" ( At around 34:40 there is a check box option labeled "Project toolpath onto 3D model" near the bottom of the profile toolpath properties section (just below where it shows Home Position and Safe-Z). That area of the display on the trial version is blank. How does this option work? How do I enable the capability?
- Vectric Staff
- Model of CNC Machine: xxx
We have given away $500 worth of FREE Design & Make clip art for all upgrades to V9 of Aspire. Attached is a PDF showing everything included4DThinker wrote:Is any new clip art included that didn't come with 8.5?
- Free D&M Clip Art with Aspire V9.pdf
- (470.87 KiB) Downloaded 225 times
- Model of CNC Machine: PRS Buddy48alpha ,4x6' 130w laser, Wazer
Adrian- I am hoping you can answer a V9 question for me. I am battling with other software and I am wondering if I can design in Aspire and export STLs for 3d printing- I know I can do it for one-sided models. I have a lot of experience with Aspire V8 and will upgrade to V9 if it will do what I desire. I want to do what is considered an undercut in V8 and produce a STL from it? This is a sample I have printed- I would like to add a feature to the bottom side and then export. Thanks Gene
Aspire handles top and bottom as two separate models. You cold export the top half of the model, and then export the bottom half of the model. You would need to merge them in a different software package.I would like to add a feature to the bottom side and then export
Thank you, Randall. Good to know. Gene
I have V9 but cannot install gadgets. Please help.
Have you got the gadgets installed under 8.5 ? If you have then you can migrate them to V9 or you can copy & paste them. Think the migrate from older version option is under the help tab at top of screen but not got software on this laptopbpastor wrote:I have V9 but cannot install gadgets. Please help.
- Model of CNC Machine: Shark HD4
I upgraded to V9 and now I am no longer able to import 3d models. Is anyone else having this problem or is it something that I am doing or not doing? An help would be greatly appreciated V8.5 is allowing me to import the same files.
Are you using the icon or menu item to import? If it's the icon make sure you're on the right tab. You can only import 3D models using the icon on the Modelling tab. The one on the Drawing tab will only import 2D models.
- mtylerfl
As Adrian mentioned, you can import a 3D model via the Model Menu (see screenshot)
Yes I am using the modeling tab and also the import under the file menu. Neither one would work I get the error message failed to load component data from file.
