Okay to use CA glue on vcarve inlays?
Postby sudo » Sat Jul 08, 2017 8:47 pm
Im doing some inlay work and im wondering if using ca glue and activator is a good idea to secure the inlay
This is an ornamental inlay. Has anyone ever tried ca glue and activator vs wood glue on a vcarve inlay?
Thanks in advance.
sudo
Model of CNC Machine: CNC SHARK HD4
Re: Okay to use CA glue on vcarve inlays?
Postby scottp55 » Sat Jul 08, 2017 9:25 pm
All CA ...1 week-3yrs now no problem. Rockler medium CA.
Have EVERYTHING ready to go and get clamped QUICK!! NOT much time to fuss with things!
Oh, 1 FULL hour or more clamping to the max in my case...usually was removing waste within 3 hours...no accelerator.
scottp55
Postby FixitMike » Sat Jul 08, 2017 10:19 pm
Place matching indexing marks on the two pieces so you can line them up easily for gluing.
FixitMike
Postby Rcnewcomb » Sat Jul 08, 2017 10:22 pm
Scott
I admire your work and your willingness to help others
Postby MarkJohnston » Sat Jul 08, 2017 10:35 pm
Scott I to think your work is awesome!!
Thanks for all your post, please keep them coming.
Mark
MarkJohnston
Postby sudo » Sat Jul 08, 2017 11:17 pm
Thanks for the info.
This might seem like a silly question, but do you use a brush to spread the glue around? Do you just count on squeeze out to spread it around?
Thanks again!
sudo
Postby scottp55 » Sat Jul 08, 2017 11:38 pm
Using the medium CA, I try to hit top edges of the female evenly, and excess pools at bottom....toothpicks/hibachi skewers to spread..clamp quickly and then invert so excess CA reinforces the waste to be removed.
NO Ca on the male parts....massive clamping FAST.....Record bench clamp works well.
I try for the most minimal gap so flat bottom adds to total adhesion.
Never yet put Ca on the Male Inlay, and it seems to work quite well.
2 reference pencil marks while dry fitted helps a LOT to get the most out of the 16 second open time.
scottp55
Postby scottp55 » Sat Jul 08, 2017 11:56 pm
If doing large areas, break up the pieces with a scroll saw to make clamping faster.
scottp55
Postby LittleGreyMan » Sun Jul 09, 2017 4:23 pm
Rcnewcomb wrote:Scott
+1
Best regards
LGM
W7 - Aspire 8.517
LittleGreyMan
Model of CNC Machine: 3 axis Charlyrobot & Mecanumeric
Postby oldlogtrucker » Tue Jul 11, 2017 2:55 am
What is CA Glue?
Camaster StingerII - FTC, Vac Table - Aspire
Embroidery - WingsXP
oldlogtrucker
Model of CNC Machine: Cam Master StingerII
Postby IslaWW » Tue Jul 11, 2017 2:58 am
cyanoacrylate glue aka... super glue or one of its clones
Gary Campbell
CNC Technology & Training
Control & ATC Retrofits
GCnC411 (at) gmail.com
IslaWW
Model of CNC Machine: SideWinder ATC & CNC Mill on WinCNC
Postby markevans36301 » Thu Jul 13, 2017 12:18 am
IslaWW wrote:cyanoacrylate glue aka... super glue or one of its clones
markevans36301
Model of CNC Machine: shopbot handibot
