Engraving a bowl
Engraving a bowl
Postby dtorney » Thu May 11, 2017 2:55 pm
engraving_example.pdf
Example
(8.1 KiB) Downloaded 127 times
I'm new to CNC and could use guidance. I'll use VCarve Pro.
I aim to make a hardwood bowl and engrave its interior with a mathematically-defined
set of curves like ones depicted in the attachment. The depicted curves
would be parlayed into v-shaped channels about 1/16" deep.
Should these channels be included in the bowl's model opened by VCarve Pro? Can
they be specified separately? Does VCarve Pro handle engraving in special ways?
dtorney
Model of CNC Machine: Axiom Pro 8
Re: Engraving a bowl
Postby Mike-S » Thu May 11, 2017 3:36 pm
After you make your bowl shape, turn the math line into a vector. Project that onto the inner bowl.
Mike-S
Postby coastingmesa » Sun May 14, 2017 10:42 am
Ah excellent. Thanks for the tip Mike. Turning the map line into a vector :)
coastingmesa
Model of CNC Machine: Touch Probe
Postby dtorney » Thu May 18, 2017 8:49 pm
Dear Mike,
Many thanks.
Can a "vector" be used to engrave one curve with one depth and another with a different depth?
I'm thinking I'd like a "v" profile. I might want its depth to change, along the curve.
David
dtorney
Postby dtorney » Thu May 18, 2017 9:13 pm
Dear Mike,
Looking at your attachments, curves in mine can sit on the surface of
the basin of a bowl, which they circle.
Best from
David
dtorney
Postby Mike-S » Fri May 19, 2017 5:38 pm
Not sure what you're asking.
You can V-carve or Profile ON, but need to check "Project toolpath onto 3Dmodel" in either case.
For V-carves, the depth is set by V-bit "pointiness" and distance between the two vectors.
For Profiles ON a vector, you can set a different depth for each vector. I don't know how you could control different depths along the same vector except maybe to play with fluting.
Below is "Profiled"; first example above was V-carved.
Mike-S
Postby dtorney » Fri May 19, 2017 5:52 pm
Dear Mike,
I'm planning to cut the bowl first and to engrave on it with the
methods you suggested. When I do, I'll post photos here.
I enrolled for the Vectric workshop in Las Vegas, 20-21 October.
That will help me come up to speed, and, by then, I'll have some
experience with CNC routing.
Many thanks,
David
dtorney
Postby JackS » Thu Jul 27, 2017 10:51 pm
Where is the workshop thru in vegas? I would like to sign up. I'm located in L.A. and desperately need to take a class.
JackS
Model of CNC Machine: SenFeng 1212
Users browsing this forum: krugshouse and 8 guests
