How does one make a PERFECTLY centered 1/8" hole in the Moon, when the preview shows a perfect cut?
(Hint: It would have looked DRASTICALLY different if I had left my .25" 30 degree engraving bit in last night)
What should you do after the choice swear words and kicking yourself?
Note;
Other certified cnc idiots need not reply, and are only allowed to politely snicker
(name omitted to to protect the guilty)
Newbie Quiz
- scottp55
Newbie Quiz
R.N.
R.N.
- dwilli9013
Re: Newbie Quiz
Well I thought that hole was foe Neil Armstrongs american flag that he planted there long ago.......
D-Dub
Dwayne
Dwilli
Dwayne
Dwilli
- scottp55
Re: Newbie Quiz
Nah Dwayne
That's Scott deciding at the last minute to change it from Z Zeroing from the spoilboard to the top of the block, and NOT getting rid of the ZZZ preface heads up on the file that tells me it's a spoilboard zeroed cut
Thank goodness It was an offset Finish toolpath!
And I had my finger on the Spacebar key (Pause at safe Z in Shopbot).
Of course it could have been a mini black hole hitting the Moon, just before it exploded into 7 large chunks like in the book "Seven Eves"
Smallest of the 4 Chinese tapered ball noses worked well in Sugar Maple(the one on the left, right side is 30degree engraving bit);
http://www.ebay.com/itm/R0-25-0-5-0-75- ... SwEzxYXyJe
Now to ramp up the speed/feed and do a larger one with the .5mm Radius one:)
OH, Always clean collet/nut/and spindle cone after trying to cut with collet nut! Lot's of smoke and gunk get in there.
Also you can guarantee you probably lost position on all Axis..so Re-zero everything.
R.N.
R.N.
