Tool path cutting too deep
Postby CaptainJaimie » Sat Feb 04, 2017 4:20 pm
I am new to the CNC, I have an Axiom Pro 6 and am using VCarve pro 8.5.
I am trying to make plaques using the 3D models and when I run it, it's cutting almost all the way through the wood. I have played with the base, height and cutting depths and nothing is helping. I want the 3D look as the face but not all the way through. I have run a smaller model and it comes out perfect. Once I start a new file, using thicker wood and larger dimensions, it starts showing it removing all the excess wood...which I don't want. Any suggestions? I have attached a screenshot of what I am talking about. Thank you in advance...I have been trouble shooting for 2 months now and am at my wits end!
CaptainJaimie
Model of CNC Machine: Axion Pro 6
Re: Tool path cutting too deep
Postby mtylerfl » Sat Feb 04, 2017 11:34 pm
Check your Model position via the material setup menu. Make sure your models are positioned at the top. A very slight gap is ok (maybe a couple thousands of an inch).
Postby CaptainJaimie » Sun Feb 05, 2017 1:10 am
Thank you for the reply. I checked that as well. I finally got it to where it isn't so deep by changing the base model depth and playing with the toolpath, however, I am also trying to clear all the extra wood out between the 3D carvings and that is cutting too deep and into the 3D models even though I traced each vector and created boundaries then used the pocket toolpath. Any suggestions? The training videos are great but very limited. I will try to post pictures tomorrow. Kudos to everyone that has this figured out and your help is greatly appreciated.
CaptainJaimie
Postby highpockets » Sun Feb 05, 2017 1:14 am
Can you upload the file without validating any copyrights on the models you used?
Postby martin54 » Sun Feb 05, 2017 2:48 am
As highpockets has said a file that you are having problems with will help but if you are unable to add a file for copyright reasons then a couple of screenshots is the next best thing.
I am not sure I understand your problem just now, you said that the smaller size cut perfectly but when you made the size larger it cut all the way through the material, I understand you have used a thicker piece of material but maybe it just isn't thick enough for the size you have made the model, if you increase the length & width of the model then you are going to increase the depth it carves to as well.
Have you checked the shape height in the model properties form ? (wrench icon second from left on modelling tab) it should obviously be less than your material thickness. You can alter the height on that form or use the scale z height of model function (5th icon along on modelling tab)
As Michael has already said check the position of your model in the material block as well :lol: :lol:
Postby CaptainJaimie » Mon Feb 06, 2017 10:41 pm
Highpockets and Martin...I have no idea how to upload the file, however, I think you inadvertently answered my question. Making the project bigger will increase the depth of the cut which makes sense. I will try the smaller version on the thicker wood but keep the thinner wood thickness in the material setup. I shall give that a try. Thank you!!!!!!
CaptainJaimie
