Page 1 of 1
lines curves qualities thereof...
Posted: Wed Oct 19, 2016 1:37 am
by RobSm
Hi.
I have modelled a fretboard in Rhino and projected the 'lines' indicating the fret positions onto the curved surface of the fretboard.
V Carve won't import the Rhino model - i get an error message regarding no meshes. (sorry I forget exactly)
If I export the fretboard model as an .stl then I get the fretboard model which I can toolpath, but the lines for the frets are missing. I waas thinking to do a profile cut on the lines like I would in a 2d dxf or the like.
Can Someone tell me how to import the fretboard with the fret lines projected onto the curved surface please?
Do I have to join or group them or something?
Rob.
ps I have tried modelling each slot and aside from being a pain I don't get a result there either.
Re: lines curves qualities thereof...
Posted: Wed Oct 19, 2016 9:02 am
by Adrian
Draw the lines where you want them and then create the profile toolpath but make sure you have the Project onto 3D option checked.
Posted: Wed Oct 19, 2016 3:37 pm
by martin54
Are the lines in your original drawing vectors? If they are than rather than trying to export them as stl with the fret board try exporting them as vectors in what ever vector format rhino supports. You can then import the fret board stl then import the vectors & lay the vectors back in the right place to 2d machine.
Posted: Wed Oct 19, 2016 7:41 pm
by adze_cnc
RobSm wrote:V Carve won't import the Rhino model
VCarve 8.5 imports rhino
version 4 models (use File > Export from version 5). At least it does NURBS. I avoid meshes like the plague so I can't guarantee that it will import them even using version 4 files.
Steven
Posted: Thu Oct 20, 2016 8:51 am
by RobSm
Thanks for the responses...I obviously don't know what I'm doing and I need to go away and read up on lines vectors meshes etc.
I thought a line was a vector and I have no idea what a mesh is.
Some things work for me and some don't.
Thanks again..I will have to study the literature.
Regards,
Rob.
Posted: Thu Oct 20, 2016 1:11 pm
by garylmast
From Rhino I always
export the model as a stl file and
export the vectors as dwf file. Both should import at the same position.
Posted: Thu Oct 20, 2016 2:41 pm
by ger21
I don't believe that you can.
Afaik, You can't import a 3D vector ( a vector projected to a fretboard would be curved in the Z direction.)
Also, I believe that any Z value of imported vectors is ignored. All imported vectors are on the same plane, regardless of there Z value in 3D space.
Imported vectors are flat, 2D only.
Posted: Sun Oct 23, 2016 1:23 am
by RobSm
well...thaanks again everyone...after much binding in the marsh I made it work!!! hahahhahahahah
why do i have make things so hard for myself....
VCarve wanted mesh data from Rhino - so - I made some duhhh
in VCarve open the dxf of the lines , import the rhino model complete with mesh
do the 3d shaping, project lines onto curved surface & cut ON
Honestly it took less than 5 minutes to do and a week & half's howling in frustration.
So...is it always like this?
) Thanks again.
Posted: Sun Oct 23, 2016 11:09 am
by martin54
