lines curves qualities thereof...
Postby RobSm » Wed Oct 19, 2016 1:37 am
Hi.
I have modelled a fretboard in Rhino and projected the 'lines' indicating the fret positions onto the curved surface of the fretboard.
V Carve won't import the Rhino model - i get an error message regarding no meshes. (sorry I forget exactly)
If I export the fretboard model as an .stl then I get the fretboard model which I can toolpath, but the lines for the frets are missing. I waas thinking to do a profile cut on the lines like I would in a 2d dxf or the like.
Can Someone tell me how to import the fretboard with the fret lines projected onto the curved surface please?
Do I have to join or group them or something?
Rob.
ps I have tried modelling each slot and aside from being a pain I don't get a result there either.
RobSm
Model of CNC Machine: Chinese 6090
Re: lines curves qualities thereof...
Postby Adrian » Wed Oct 19, 2016 9:02 am
Draw the lines where you want them and then create the profile toolpath but make sure you have the Project onto 3D option checked.
Postby martin54 » Wed Oct 19, 2016 3:37 pm
Are the lines in your original drawing vectors? If they are than rather than trying to export them as stl with the fret board try exporting them as vectors in what ever vector format rhino supports. You can then import the fret board stl then import the vectors & lay the vectors back in the right place to 2d machine.
Postby adze_cnc » Wed Oct 19, 2016 7:41 pm
RobSm wrote:V Carve won't import the Rhino model
VCarve 8.5 imports rhino version 4 models (use File > Export from version 5). At least it does NURBS. I avoid meshes like the plague so I can't guarantee that it will import them even using version 4 files.
Steven
adze_cnc
Postby RobSm » Thu Oct 20, 2016 8:51 am
Thanks for the responses...I obviously don't know what I'm doing and I need to go away and read up on lines vectors meshes etc.
I thought a line was a vector and I have no idea what a mesh is.
Some things work for me and some don't.
Thanks again..I will have to study the literature.
Regards,
Rob.
RobSm
Postby garylmast » Thu Oct 20, 2016 1:11 pm
From Rhino I always export the model as a stl file and export the vectors as dwf file. Both should import at the same position.
garylmast
Postby ger21 » Thu Oct 20, 2016 2:41 pm
I don't believe that you can.
Afaik, You can't import a 3D vector ( a vector projected to a fretboard would be curved in the Z direction.)
Also, I believe that any Z value of imported vectors is ignored. All imported vectors are on the same plane, regardless of there Z value in 3D space.
Imported vectors are flat, 2D only.
ger21
Postby RobSm » Sun Oct 23, 2016 1:23 am
well...thaanks again everyone...after much binding in the marsh I made it work!!! hahahhahahahah
why do i have make things so hard for myself....
VCarve wanted mesh data from Rhino - so - I made some duhhh
in VCarve open the dxf of the lines , import the rhino model complete with mesh
do the 3d shaping, project lines onto curved surface & cut ON
Honestly it took less than 5 minutes to do and a week & half's howling in frustration.
So...is it always like this?
:o) Thanks again.
RobSm
Postby martin54 » Sun Oct 23, 2016 11:09 am
No not always, now you know how that particular operation works it will only take you the 5 mins next time :lol: :lol:
As for the 2 or 3 million other things you will want to know or learn then only time will tell :lol: :lol: :lol: :lol:
If you haven't already then spend a bit of time using the tutorials & quick tips videos, lots of very useful info on using the software. They have certainly answered a lot of my questions :lol:
