Text sizing for dates ect.
Postby chrispy » Tue Sep 06, 2016 3:10 pm
Hi, when setting out a job that includes a date I often want to put in the date as the 1st or 22nd ect. now some software reduces the size and position of the "st" "nd to the upper right corner of the date number, is there any way to to this in V-carve? because if there is I can't find it and it is a right fiddle to do as a separate line entry in smaller text. :evil:
Thanks for any help.
chrispy
Model of CNC Machine: RYE Quantum maxi
Re: Text sizing for dates ect.
Postby glenninvb » Tue Sep 06, 2016 3:20 pm
may not understand your question but you can convert the text to curves and select the "st" "nd" and set to what ever size you wish and position where you wish
glenninvb
Model of CNC Machine: homebuild / VCP 8.0
Postby Adrian » Tue Sep 06, 2016 3:24 pm
VCarve has no superscript/subscript setting for fonts so DIY is the only way in the way Glenn describes.
Postby chrispy » Tue Sep 06, 2016 4:20 pm
glenninvb wrote:may not understand your question but you can convert the text to curves and select the "st" "nd" and set to what ever size you wish and position where you wish
Yes that's what I've been doing Glenn but it's a fiddle especially when wrapping round curves and then changing spacings to even things up.
chrispy
Postby chrispy » Tue Sep 06, 2016 4:22 pm
Adrian wrote:VCarve has no superscript/subscript setting for fonts so DIY is the only way in the way Glenn describes.
Oh well at least I haven't been missing anything obvious then!
chrispy
