11 posts • Page 1 of 1<Previous topic | Next topic>
martin54 wrote:I just square out the corners with a file, your not removing a lot of material so only takes a few seconds, could use fillets as Mike has suggested but when I made most of the jigs I am using I didn't think to do that![]()
You will need to make your pockets fractionally larger than the parts that will fit into them but do this in very small stages or you will end up with a very sloppy fit which will allow the parts some movement in the jig.
This tutorial is about 2 sided machining but they use a jig for alignment.
http://support.vectric.com/tutorials/V8 ... rts_2.html
There is also a video by Andrew Pitts somewhere where he makes a jig that uses a wedge shaped piece to lock the parts in place but I can't seem to find it just now.
zaxis wrote:I am trying to cut mortise pockets and, the tenons (rabbits) to match
