climb or conventional
Postby rbclayton84 » Thu May 19, 2016 6:35 pm
which have you found works better for 3/4" plywood material,,, climb or conventional direction?
rbclayton84
Model of CNC Machine: Laguna tools Swift 4 x 8 router
Re: climb or conventional
Postby ger21 » Fri May 20, 2016 2:32 am
Conventional almost always gives cleaner cuts. The only time I climb cut wood products is when cutting rabbets that are running with the grain.
ger21
Postby dealguy11 » Wed May 25, 2016 3:20 am
Depends on the machine. On mine, I cut ply, MDF and melamine with a 3/8" compression bit, most of the way through leaving a 1/32" onion skin that gets cut through last. If I cut conventional I sometimes get a step when the final cut goes through the onion skin, which messes up the edge bander. Cutting climb avoids this. Appears there's a little flex and the bit is pulling into the material during the initial deep cut.
Steve Godding
dealguy11
