Hi all, thanks for reading my post... I am still learning VCarve and trying to do something that I could use some help with.
I am overlaying text onto a map of the world. I want the text at the top and the world 1/8" or so below. The problem is that I have to do the text first, then when I trying to engrave the world, the two overlap. See picture.
is there an easy way to trim the closed vectors so the letter can be in front of the map?
How to clean up intersecting Closed Vectors
- Model of CNC Machine: Shark HD3
Chris
Shark HD3 / vCarveDesktop 10.512 / CNC Shark Control Panel v2.1 Build 22
Re: How to clean up intersecting Closed Vectors
You could use layers.
Text on one layer
Other vectors on a different layer
Turn on only the layer you want to work with
Text on one layer
Very simple to do.chris@manabeads.com wrote:Hi all, thanks for reading my post... I am still learning VCarve and trying to do something that I could use some help with.
Select all the "world" vectors. Then select the letter. Then use the "Trim Objects" tool (just to the left of the scissors), and select "Clear inside boundary".
Done.
WOW! That was easy. Thanks so much... Learning more every day!!!!Frunple wrote:Very simple to do.chris@manabeads.com wrote:Hi all, thanks for reading my post... I am still learning VCarve and trying to do something that I could use some help with.
Done.
Chris
