How to clean up intersecting Closed Vectors
Postby chris@manabeads.com » Mon May 02, 2016 4:45 pm
Hi all, thanks for reading my post... I am still learning VCarve and trying to do something that I could use some help with.
I am overlaying text onto a map of the world. I want the text at the top and the world 1/8" or so below. The problem is that I have to do the text first, then when I trying to engrave the world, the two overlap. See picture.
is there an easy way to trim the closed vectors so the letter can be in front of the map?
chris@manabeads.com
Model of CNC Machine: Shark HD3
Re: How to clean up intersecting Closed Vectors
Postby Leo » Mon May 02, 2016 4:51 pm
You could use layers.
Text on one layer
Other vectors on a different layer
Turn on only the layer you want to work with
www.leosworkshop.com
Leo
Postby Frunple » Mon May 02, 2016 5:47 pm
chris@manabeads.com wrote:Hi all, thanks for reading my post... I am still learning VCarve and trying to do something that I could use some help with.
Very simple to do.
Select all the "world" vectors. Then select the letter. Then use the "Trim Objects" tool (just to the left of the scissors), and select "Clear inside boundary".
Done.
Frunple
Postby chris@manabeads.com » Mon May 02, 2016 7:43 pm
Very simple to do.
Done.
WOW! That was easy. Thanks so much... Learning more every day!!!!
chris@manabeads.com
